Skunk2 B Series TypeR Intake Manifold
powerautohauz
((( God Level 30,000 RPM )))
Skunk2 Racing’s Pro-Series Intake Manifold improves airflow thus increasing horsepower by as much as 8% over stock manifolds on stock engines and even more on modified or forced-induction engines. Skunk2 manifolds significantly increase horsepower between 3000-8800 rpm; the broadest powerband increase in the industry. Pro-Series design features a 22% increase in power over our previous design. Engineered with a larger plenum and tapered runners, Skunk2 manifolds increase and accelerate airflow, and are designed to increase the effects of wave scavenging at the engine’s optimum operating RPM range providing a broad overall increase in usable power. Each runner entry is also modified to balance airflow between cylinders. Oversized throttle bodies can be used as a result of the modified IAC opening on the flange. Like OEM factory manifolds, Skunk2 manifolds are shell molded and CNC machined, to achieve superior strength, high-quality finish, and a precise fit. Each manifold is vacuum tested to ensure quality and leakfree operation. The Skunk2 Pro-Series manifold utilizes all stock sensors and auxiliaries for a simple bolt-on installation that delivers maximum power. Ideal for NA and Forced Induction
Installation upon request with reasonable satisfy charges.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
