Simota (Works-Engineering) Stainless Steel High Flow Drop-In Replacement Air Filter for TOYOTA WISH 1.8, 2.0, CAMRY ''''01-''''02, CALDINA ''''02 NA
Simota''''s stainless steel stock replacement air filters are made from high grade stainless steel with a unique EPDM (Ethylene Propylene Diene Monomer) light weight rubber frame which is molded using the most advanced one-piece extrusion technology.
http://www.12v.com.my/store/pic/12v/item/Simota_Replacement_01.jpg
http://www.12v.com.my/store/pic/12v/item/Simota_Replacement_02.jpg
Features:
* Designed to reduce intake restriction and provide maximum air flow & filtration in your factory airbox.
* Unlike conventional drop-in air filters made of paper or foam elements that require oil to maintain filtering capacity, Simota air filters are made of a non-woven fabric and can be used with or without oil.
* Simota air filters are made of a lightweight unique EPDM one piece extrusion molded rubber compound frame. This means that the frame and filter will not seperate under harsh conditions.
* One-piece extrusive-form ensures the performance and structure stays in excellent condition at all times. Our huge corrugated walls increases surface area and ensure more air is sucked into your intake increasing horsepower up to 7%. This is the last air filter you will ever need.
Details:
* Application: Simota Replacement Air Filter for TOYOTA WISH 1.8, 2.0, CAMRY ''''01-''''02, CALDINA ''''02 NA
* Made from Stainless Steel, Durable Rubber & Nonwoven Fabric
* Higher air intake and more dust absorbing than original paper air filter.
* Increases Horse Power: 5% - 20%
* Increased fuel economy
* Unique EPDM frame 1-piece extrusion molded
* Light weight and strong
* Washable (Highly Recommend Simota Air Filter Service Kit)
* Recomended for improved performance
* Original WORKS ENGINEERING Product
* Condition: Brand New Sealed In Box Manufactured By SIMOTA and branded by Works Engineering
For more info, you can visit
http://12v.com.my/Simota-Replacement-Air-Filter-for-WISH-1.8-2.0-CAMRY--01--02-CALDINA--02-NA/q?pid=290&doit=order
Alternatively, you can email me at [email protected]
or call me at the number listed to the left.
Thanks!
Features:
Details:
Thanks!
