++ share ur car speed video ++
garytrd
2,000 RPM
this is bt test speed on the road.
but how come too slow ? ?
pls take a look .
http://video.cardomain.com/clip.aspx?key=2EB892334664A492
first gear 55~60, 2nd gear 100~110, should be 4.1 final, what engine oil you use? rev went up bit slow la
ya lo.... very slow of my engine.... , i used 4-2-1 with twin muffer n use ORG TOYOTA engine oil lo:confused: :confused: :confused:
how ?
no body can show / share ur car speed ?
why my car too slow ? ? ?:confused:
here is mine.. standard bt 20v 6speed..
[media]http://www.youtube.com/watch?v=W2mWSO6hUas[/media]
the other one..
[media]http://www.youtube.com/watch?v=NKW9vhtf8MU[/media]
quite slow also meh.. plus scared hit somebody on the road.. test haram.. lol...
I don't know also....
Look like very slow lo....
Not like u all can run to faster le...
Is't my car got problem.....
Pls give me a suggustion
thanks
the other one..
CAN'T SEE LE HOW ? :itsme:
wowowo....recorded using HP? tat HP shud be expensive..so clear sial...
carbon fiber @@...and why there are red light blinkking at the panel there? is not tat a WARNING from your engine tat you;re going too fast?hahaha..kidding bro
thanks
My engine (BT 6spd) after 4K rpm, it'll shoot up to 8K rpm very fast at 1st, 2nd and 3rd. I think when the VVT on, the rpm will shoot up quite fast. some times i can even miss a good shift..... hahaha..
Is your car heavy (lots of loads)? Is the A/C on? did your car gone for dyno? ECU standard or piggyback? lost compression - overhauled it recently? BT flywheel?
banyak posibilities....la
wa can be like this ah? ? ? ?:bawling::bawling::bawling:
i have vvt power light , try to see on the meter got green color right.
when the vvt open can see the light working.
but i'm too slow also.
i'm never on the A/C n never go to dyno, i used ORG ECU BZ-R , but 5speed la.... hee n never use any piggyback
all is standard.
what size u use the exhuast full set ?
i'm used FGK TWIN now. : s
is't clear sial mei..... hee hee
that's green light. when the vvt open the light will blinkking lo.....
heee....
thank you
Bravo ... finally local made BT video... I want more Please...I will post mine when my video man managed to get a clearer vision:stupid:..as 4 now..all are dark ... early morning drag bah..illegal lagi tu ...
from what i see, i think its quite okay as my car has roughly the same acceleration levels as the video. just to compare, i'm driving an ae111, stock blacktop engine with normal 2.2 inch straight flow.
that's good...
pls upload ur speed test video to share to every one
thanks
all is standard.
Bro, i'm using 3" piping with "perut" and 3" muffler (single)... "Marco" brand
me too using a standard 6spd ECU and standard BT, only thing i mod is the exhaust and the Air Filter (HKS Drop in filter) stock housing.
Sounds damn garang:biggrin: i think :hehe:
But this vid is not when i speed, just to show u my exhaust and the problem i'm facing.
[media]http://www.youtube.com/watch?v=p0d1YLcmDWI[/media]
what do you mean by cant see? cant see the link or cant see the different?? by the way, i think ur car same like other standard bt what... except u have change alot example cam,ecu,clutch etc... if u do, ur car definitely slow.. if not, just drive happily like other toyota's family.. :biggrin::biggrin::biggrin:
so what i can do it now ?
change back the exhuast or going to doing the engine setting ?
thanks
