Re: Share experiance on 4AGE engine
1)after retard IG timing to 10deg,is more better now.may i know the diff between 10 n 15 deg?
>> 15 deg will have better pick up compare to 10. But 15 will make your engine knock like crazy.
yes bro,it jerk(juz 1 sec) when rpm reach around 3k,after tat rpm is keep going up like normal.wat the prob,bro?spark plug shown lean.
>> you may have fuel interruption. When was you last time changing the fuel filter? Other possible area: dirty fuel pump pocket, faulty FPR.
2)bro,how to check ISCV condition? n how to re-adjust aircond idling valve?can tis do it by myself,or need to send to mech?
>> better leave it to you mech. But if you want to DIY, visit chinozie's website first.
3)yes,im using stock alternator.i dun know wat my headlamp rating,but it oledi add some component to make it more light n lamp bulb have change too.
i find out when the aircond fan(oledi change to high speed fan)start working,voltage drop much more than other.izit tis fan not suitable?need to remove it?
>> no need to remove. High speed fan is ok.
bro,how to solve tis prob?need to replace alternator or battery?izit useful change to battery ns70,my current is ns 60.
>> stay at 60. Your alternator may not able to generate enough charge for 70.
confused.. Well, it goes like this..
