- Joined
- Feb 22, 2006
- Messages
- 971
- Points
- 1,516
Wira Vr4 ready 450hp & Wide body e5 customz
Selling REASON dont want to mod wira vr4 * bodykit evo 5 custom near to 4k..
going to try on wira evo3...TQ...accept trade in for my friend used car but the price will be more abit down like 1-2k ..~
Wira 1994 years ORi 1.5 Chassis
Converted Vr4 with 240hbps block
Running ECU VR4
JPJ approved.
Exterior :-
Bonnet Evo5 look Custom
Bumper Evo5 look Custom
Fender Wide Evo5 Look Custom
Rear Evo5 Look Custom Solid Style
Rear Bumper Evo5 Look Wide
Side SKirt dont know ..Nice 1
Roof Scoop Subaru Small scoop
New Silcon Wiper only use 1 time
Painted color is Black metalic + Honda Champion white
Wheel and Suspension :-
Running 4 Point Struct bar Front
Absorber
Hks Hiper -D
114.3 Yokohama ori from Japan Rim MODEL: : AVS Model T-7 (ori and unique in malaysia)
front Bridgestone my'01 215/45/17
Rear Yokohama Es100 215/50/17
Fully Evo3 Discbrake rear come with evo3 arm
Front using 4G63T Driveshaft
Engine , Performance stuff
Engine 4G63T (Vr4 ori 220hbps) BLock Changed 240block and piston also
Turbine Running T67 Hybrind - 25G
Wastegate 40mm
Radiator Double layer 9L
Extractor change longer
Inlet Manifold Changed Shorter ( ball 70mm hole)
Throttle Body 80mm (from Fairlady
Full Stainless Piping ( 3" and 2.5" only )
intercooler (same as evo8 column custom)
oil Cooler original vr4
Sheepdog BOV
Exedy Full Clutch System running Super Single 9" ( as hard as a Lorry) from japan
atzos pipe 2.5 inches till end ..muffle is 3in and out ..
Oil Catch Tank - Arospeed
New battery change 1 week only
Interior
Tachometer 5" Power Gauges
HKS turbo timer Type 1 the good 1
Greddy 52mm new type 1 ..can boost 2.0 bar
NO soundsytem
Steering with Boss kit
original 1.5 seat
GTI replica Gearbox console
Carbon fiber Look Armrest ( patah kaki )
Alarm system changed (normal)
Tinted is fully 65-75% black for raer and 4 door
front TInted is Approved.
alraedy Wiring Sound Voice Module
( ready for your car sound louder the sound follow your song or your engine + the 4 door and dashboard got green light .. follow bass or engine sound lo.if loud that time )
For Current Car Spec
after Market Stand alone ECU + Fuel Pump more than 200lb + 550cc above injector no need high cam tested is 450hbps.
IN 6 MONTH TIME ALREADY
RENEW PAINT
CHANGE NEW BLACK OIL
CHANGE NEW GEAROIL
1 MONTH OIL SUPER BOSCH 4 WITH NGK-R PLUG WIRE
With the pricing Selling at RM33k NEG.
Change a modified Vr4 Gearbox from japan final Gear 4.55 (DC2type r is 4.44) (TOPSPEED CAN GO 260KMPH NO PROBLEM WITH THE MODIFIED GEARBOX HAVE TESTED)
Change New Radiator
Change new wastegate
change new Metal casket
CHANGE FUL GSR DASHBOARD COME WITH METER,DIGITAL AIRCOND ,AS LONG IS FULL
IF FOLLOWING ABOVE ALL CHANGE TO NEW
RM 34K NEG ABIT ONLY
IF DONT NEED TO DO ANYTHING CAR PRICE IS AT ALSO NO NEED PROVIDE ANYTHING
RM29500 BEST PRICE ..WITH EVERYTHING BRANDED GO WITH..
0166688899 BERTDEEN . MY NUMBER PLEASE CALL ME FOR FUTHER INFOMATION..
0166688899 OR MSN @ [email protected]
IF U NEED MORE PHOTO PLEASE LEAVE YOUR EMAIL CORRECTLY .. I WILL SENY .. THE FILE ALL TO BIG ..TQ
http://www.friendster.com/bertdeen30 ( it should be can view my photo .. tq~)
Running ECU VR4
JPJ approved.
Exterior :-
Absorber
Hks Hiper -D
Wastegate 40mm
Sheepdog BOV
Interior
NO soundsytem
original 1.5 seat
RENEW PAINT
CHANGE NEW GEAROIL
Change New Radiator
