steel braided brake hose help my olskool car to haf a better braking feel.
but i tink the price now is a bit too steep..
i tink u shud really consider do brake flushing 1st.
Brake flushing does help?
But after the 3rd service I have sent the car service outside due to company issue. Do u think still can get free?
---------- Post added at 09:33 PM ---------- 6 hour anti-bump limit - Previous post was at 09:32 PM ----------
How long does the pad n disc need bedding in?
go to the sc when u r due for servicing, usually they allow warranty claim with one condition...u do 1 major service there...then u r back on track...give them strong reasons for not servicing yr car at proton....
My Myvi had a rather similar problem, when initial press of brake there is slight bite but it is not continuously biting. When the brake pedal almost reach floor will have additional bite usually causing the car to jump over a bump as I was unable to accurately control the braking speed. good thing my foreman is experienced. Found out it was due to master pump.
slightly out of topic, what tire are you currently using? size?
brand and model?195/50/R15
Wrong size?
brand and model?
195/50/R15
Wrong size?
If you send back to SC, sure they will change your pads back to OE ones. Since only 8 days old, still think they are not bedding in yet.
You can also check your servo working or not. With engine off, step hard on your brake pedal until cannot move down anymore, then start the car. Once the engine starts the pedal should go down some more to show that the servo is working.
If you need fast fix, change the pads to Bendix General CT. They come with bedding material on the pads to aid bedding in, so you get instant feedback.
---------- Post added at 08:00 AM ---------- 6 hour anti-bump limit - Previous post was at 07:59 AM ----------
To me is not the tyres, unless oversize, but 195/50R15 is okay....
Except General CT. Is the FBK have the bedding aid too?
As far as I know only Bendix brand have. CT, Metal King also.
Does tis pad work in cool braking?
Yes, General CT works from cold, but not Metal King, which needs about 1 to 2 km of drive before getting better bite.
I'm Driving Saga Brake Lagi Makan (A). So far, I find that the stock brakes are not too bad if compare to Myvi. I'm not sure
but my own preference, I still find it good, just that it will lock my wheels at times like late sudden emergency brake when
I didnt see a bump, it will skid a little. Wheel Lock.
Just to me, the car brakes are okay, just no ABS so will skid. Maybe shud get the SC to check.
The only thing that irritates me is that the SC told me that cars with brake drums is like that....sure will have the screeching
sound, then i ask? so what can u do about it? Nothing is normal, when the drums warms up then is okay cuz is just all the
brake dust gather inside adi...
Then my friend told me to insist to change Brake Drums next SC, I dont think they will change for me other than me writing in
to their HOD...
Will try to ask for a change for the brake drums, adi repair for me more than 3 times still same. No sound awhile, after 1 month
come back again...
Brought General CT. Will change later & try how is the result.
---------- Post added at 12:56 PM ---------- 6 hour anti-bump limit - Previous post was at 12:55 PM ----------
If u r talking bout braking sound. Tat might b the rear drum brake pump jam & causing the sound of screeching.
to their HOD...
come back again...
Yup, screeching especially when it is cold. Really beh tahan...just like telling everyone im going
to work every morning![]()
Will get them to replace it since adi more than 3 times still same...
