Rockford Fosgate EPX2
ICE -In Car Entertainment
vickyz
Rockford Fosgate EPX2 with independent 28 band eq card.
Price: RM1500
Contact: 0162510646
Rockford Fosgate created the computer controlled Symmetry EPX2 for total control of the audio spectrum in one technologically advanced unit containing a 10 channel crossover, dual input full function preamp, all controlled by a 16 bit computerized RDAT (Remote Data Access Terminal). Equalization is handled by an optional 28 band or 14 band EQ card (not included) easily adjustable from the listening position. Special features like VDISC and the Global Save feature have made the EPX2 the number one processor among winning sound off competitors.
Features:
* Expandable Pre-Amp and Crossover
* 10 Channel Crossover
* Full Function Pre Amp
* Optional 14 or 28 Band EQ
* RDAT Remote Control
* Real Time Adjustments
* Balanced and RCA Line Inputs
Specifications:
*Model *SYM-EPX2
*Description *EPX2 - Expandable Preamp & 10-channel Crossover with RDAT
*Input Voltage (VRMS) *500mV-4V RMS
*Output Voltage (VRMS) *5 VRMS (HP/BP/LP)
*10 VRMS (AP)
*Signal-to-Noise *94dB @ 1kHz ref. 1 volt
*Output Impedance *50 ohms
*EQ Centers (Hz) *45Hz (Bass)
*15kHz (Treble)
*EQ Boost/Cut *+/- 12dB
*Crossover Frequency *Front HP = 182Hz->20k
*Front BP = 58Hz-7.5kHz (low side)
*Front BP = 182Hz->20k (high side)
*Rear HP = 182Hz-7.5kHz
*Rear BP = 58Hz-7.5k (low side)
*Rear BP = 182Hz->20k (high side)
*Low Pass = 58Hz-7.5k
*Crossover Slope *12dB/octave Butterworth
*Height (in/cm) *EPX2 = 2.25" (5.71cm)
*RDAT = 2.88" (7.31cm)
*Width (in/cm) *EPX2 = 6.88" (17.47cm)
*RDAT = 7.00 (17.78cm)
*Depth (in/cm) *EPX2 = 8.14" (20.67cm)
*RDAT = 0.88" (2.23cm)
