RM Modified Spark Plug(Made In USA)Rm250 per set.....come come come!
WalBro(Apexi)
Perak
RocketMotorsport Modified Spark Plug(Made In USA)Rm250 per set.....come come come!
Makes more power than iridium or platinum plugs.
Helps prevent high RPM spark/flame blow out.
Dyno Proven. Link to unbiased test here.
Modified in house.
Sold in sets of four.
Comes pre-gapped.
Four heat ranges available.
150-220whp - recommend #3924
240-280whp - recommend #3923
Pm me now!u can fell the different!
from the pic, they look like Autolite's...
what do u mean with "modified"?? does'nt sound very convicing...
in normal heat range terms, where are these?? 6?7?8?
yeah!Autolite!home hand modified by rocket motorsport usa.very very popular in usa!dyno proven!check in honda-tech.com.more better than denso and other expensive plug.don't waste ur money on that.
Let me preface this by saying that JUN3 are great camshafts and rightly so because most people have not found camshafts that make better power. This does not mean it can not be done. (Important lesson here: DO NOT LET THE LIMITATIONS OF OTHERS LIMIT YOU).
Before I go into specs and details, RM is and will always be grateful that the owner of this motor Arno (98itr484) for putting together a bad ass motor and gracious enough to share his dyno tuning sessions. THANKS ARNO AND FRIENDS!!!
I expect to see a 25 - 28whp gain from the m22 cams / Rocket Head
So far Arno is 10hp over his previous setup even with the stock injectors maxed out and the run cutoff at 8.0K due to fuel starvation.
Old Setup 205.6 whp / 131.8 tq
Intake: J's Racing
Throttle Body: ITR
Intake Manifold: ITR
Injectors: Stock
Camshafts: JUN3
Springs/Retainer: JUN Dual Springs / JUN Ti Retainers
Valves: ITR
Cylinder Head: ITR
Cam Gears: JG Adjustable
Bottom End: USDM ITR 81.00mm Bore
Compression Ratio: 10.6
Header: SMSP 1.8L 4-2-1 Odd Paired Long Tube Header
Exhaust: Spoon
Fuel Management: Chipped P28 w/ VAFC
New Set-up 223whp / 145 tq on most recent re-dyno. 230+ with Shawn Church Magic Intake.
Graph shown is 215.8whp initial dyno.
Intake: Same
Throttle Body: Same
Intake Manifold: AEBS
Injectors: Same
Camshafts: M22 254 duration @ 0.050. 12mm Lift In/ Ex
Springs/Retainer: RM G1 Springs / G2 Ret 95lbs on the seat, 265 at 12mm
Valves: Supertech 33.0/28.0 Int/Ex flat faced valves
Cylinder Head: RM J4 B16 Head. High Flow / Low Turbulence Ports. Milled 0.025
Cam Gears: Same
Bottom End: Same
Compression Ratio: 11.2
Header: Same
Exhaust: Buddy Club
Fuel Management: Hondata S200
