Replace Gear Oil
Steve@
Hi, is there anyone here change gear oil for is250? Some forum mentioned gear oil has been fully sealed and better don't change it. My ride was 5 years since production but Millage only 54km. Not sure need to do any replacement or not? Hope any sifu here can advice..
hey there..ed78 you had it the opposite..
gearbox oil is world standard so you dont have to change it under normal driving conditions and rear diff oil change it every 30k or every 2 years..
cheers
cheers
hahahhahaha..........silap.........
bro could you list the types fluids and the recomended changes?
I've replaced my car differential oil @ last service.
TRD differential oil, gear changing alot faster. especially when dropping gears. the rubberband symptom is lesser.
lexus car manual did not mention on diff oil usage.Anyone can share how many littre needed in is250?
I replaced my rear diff oil with Motul 75-90W ( 1 litre)
http://hangar9k.com/images/categories/motul%20gear%2075-90.jpg
Cost about Rm 120....
cheers
I just changed my ATF Fuild ..... got a shock with the colour of the fluid...macam Nescafe colour
The new fluid is Redish in colour....
After changing the ATF....the gear change upshift faster than before and cruise much smoother.
Would recomend to change ATF and the GB Filter eventhough is a maintenance free.
may i know where you change and how much it did.
I did it at Vision
I brought my own ATF Oil ( 4litre x 2) & drain pan gasket . ( But they no longer accept parts brought along by yourself now)
So the only charges as below
ATF Oil Filter - RM 220
Labour - RM 80
Flushing Machine Pump - RM 50
Any good workshop recomendation to do the ATF change beside vision ?
sorry guys what is an atf filter?? How much?? And where is it located? Thanks
the filter is recommended to change every 2 interval service i.e every 40000km if i am not mistaken...
i heard to replace this is a total pain in the ass, few hours and they need to remove rear seats! or am i wrong and that this part is actually accessible in one open space in the engine bay....? thanks
---------- Post added at 11:21 PM ---------- 6 hour anti-bump limit - Previous post was at 11:19 PM ----------
any diagrams to show where this filter is?
Its pretty straight forward.
You can access to the ATF Filter after you remove the ATF Oil Pan..
---------- Post added at 11:40 PM ---------- 6 hour anti-bump limit - Previous post was at 11:38 PM ----------
That black piece is the ATF Filter.... its inside the Oil Pan
attachment.php
