S sta 500 RPM Senior Member Joined Dec 26, 2004 Messages 639 Points 3,018 Nov 27, 2006 #1 how to remove tree sap from the car ? any suggestions ?
S soulfly_blues Junior Member Senior Member Joined Nov 20, 2006 Messages 8 Points 1,501 Nov 27, 2006 #2 i tried to use Waxco Tar Remover which could be easily applied and can be found on normal automotive department in the hypermarket. its works miracle..
P putra4767 500 RPM Senior Member Joined Sep 13, 2004 Messages 553 Points 3,016 Nov 30, 2006 #3 use diesel or petro slightly...but rinse off immediately if too stubborn the stain
S sta 500 RPM Senior Member Joined Dec 26, 2004 Messages 639 Points 3,018 Nov 30, 2006 #4 thanks for your suggestions i will try them both prize will be awarded to whichever member solution works
S sta 500 RPM Senior Member Joined Dec 26, 2004 Messages 639 Points 3,018 Dec 4, 2006 #5 doesnt work leh anyone know where to get acid? i wana apply acid then polish it.
S soulfly_blues Junior Member Senior Member Joined Nov 20, 2006 Messages 8 Points 1,501 Dec 5, 2006 #6 acid can be found in big hardware shop, try ask if they have some sort of not so strong acid, hmm wonder why the WAXCO Tar Remover not working...
E EcstacyElmo 1,000 RPM Senior Member Joined Nov 15, 2003 Messages 1,132 Points 3,138 Location K Hell Shitty Dec 5, 2006 #7 try some organic solvent like thinner or some alcohol tree sap organice mah...erm...vinegar maybe?
