R roadcrew Known Member Senior Member Joined Mar 9, 2006 Messages 415 Points 1,516 Sep 24, 2006 #1 what is the size of 99'putra rear anti roll bar.what is the best size of the anti roll bar upgrade??16mm or 19mm???
D Dremel 1,000 RPM Senior Member Joined Nov 19, 2003 Messages 1,035 Points 3,136 Location Ampng Nrdschlff Sep 25, 2006 #2 stock would be 13mm thick Last edited: Sep 25, 2006
R roadcrew Known Member Senior Member Joined Mar 9, 2006 Messages 415 Points 1,516 Sep 25, 2006 #3 12mm for the rear.then what is de front??
R roadcrew Known Member Senior Member Joined Mar 9, 2006 Messages 415 Points 1,516 Sep 25, 2006 #4 pls give advise
D Dremel 1,000 RPM Senior Member Joined Nov 19, 2003 Messages 1,035 Points 3,136 Location Ampng Nrdschlff Sep 25, 2006 #5 1997 - early 1999' putra - 23mm front.. 13mm rear 1999 - 2000 putra - 18mm front.. 13mm rear
N nuggyn Known Member Senior Member Joined Feb 12, 2004 Messages 309 Points 3,018 Sep 25, 2006 #6 how come the newer putras get smaller diameter ARB? save costs izzit?
R roadcrew Known Member Senior Member Joined Mar 9, 2006 Messages 415 Points 1,516 Sep 25, 2006 #7 mine is 99 can change to 97 front arb?? the rear uses 13mm then is 16mm upgrade gud enough?or go for 19mm??
