Proton Wiper / Pump wont work anymore!
ambayah
Help guys,
I noticed that the fuse got burnt so I replaced another 15A fuse. The minute I tried, it instantly burnt again so must be some short circuit.
What are the possibilities? Can DIY? So many problem already.
You mean, after replacing the 15A fuse, and you try to 'use' your wiper, the fuse burn again?
Maybe your wiper motor short circuit already... Can get a second hand wiper unit (with 2 pumps) for ~RM30 only.
I had a similar case exactly a year ago. Lotsa replacement fuses were burnt. So I brought my car to a wireman to check. After he scrutinized thoroughly, the culprit was the car jack in the boot. It was shifted few mm's from the comparment and made direct contact with core wire of the rear brakelight. It was so funny, I never realized such thing could happen but it did. lol.
Same thing happened to a friend oso. You might want to check it.
if not, it could be something else le.
