Proton Satria (M) 4G67T
nija
Satria 4G67T
Body :
Satria first model (chassis from Mirage Cyborg R)
Sapphire blue colour
Engine:
Blue print 4G67 to turbo spec 4G67T engine (oil squitter installed for piston lubrication)
Fully balanced engine (crankshaft, flywheel, pressure plate) + balance shaft taken out from block for lighten purposes
ACL race bearings (gold edition) main + conrod bearings
VR4 RS Piston + Conrods + Crankshaft (more harden than Evo spec)
MMC (Mitsubishi Motors Corporation) original 1.5mm metal gasket
Brian Crower Stage 2 camshaft (272 Degree) + Brian Crower valve springs + Viton seals
HKS camshaft pulley
ECI Multi intake from VR4 RS + Evo 3 60mm throttle body
Full stainless steel piping from intake to intercooler
WORKS Stage 2 fuel regulator
Evo 3 510cc injectors + internal GSR fuel pump & BOSCH external fuel pump
Greddy RS blow off valve
Original Garrett T04E (AR50) Hybrid turbo (combined with TD05 compressor) upgraded version
Tial MVS 38mm wastegate
Evo 3 custom intercooler
Evo 3 oil cooler systems + VR4 RS oil filter adaptor
Full wiring Evo 3 engine + ECU Evo 3 (2364)
E-Manage comes with basic & injector harness
Evo 3 4WD gearbox (locked to 2WD)
VR4 RS lighten flywheel + Exedy 3 puck clutch plate + pressure plate Evo 3
Racetech shifter bearings
Interior:
Evo 3 black dashboard + digital aircond controller + Evo 3 meter cluster
OMP deep dish steering
Ralliart gear knob + Evo 3 C’s commorade short shifter
Ralliart pedals
Satria GTi door panels
HKS original mechanical boost meter (2 bar)
HKS Turbo Timer
Greddy Profec B boost controller + Greedy boost solenoid complete wiring
SSCUS seats (front) Mirage (rear)
Pioneer CD player
Exterior:
Evo 3 front hood (fiber)
Original SE bumper + Original SE lips with tow cap + Original SE grill
BOSCH original headlamps
Original Proton double layer windscreen
Mirage Cyborg R side skirts
Mirage Cyborg R spoilers
Handling:
GAB SS Series Hi Low Soft Hard monotube adjustable suspension (Japan)
Evo 3 lower arms + antiroll bar
VR4 RS 2 pot calliper + cross ventilated disc (front) 1 pot calliper + cross drilled AXT turbo disc
Advan RG 17” wrapped with GT Radial Champiro HPX (205-45-17) tyres
Exhaust system:
3” custom downpipe from turbo compressor
3” full straight piping from front to back OEM flow
Original HKS Super Dragger 3” muffler
Price:
RM26,000.00 with JPJ endorsement & minor wear and tear replacement
RM25,000.00 without JPJ endorsement & minor wear and tear replacement
*price will be negotiate with serious buyer during viewing – nego till let go
Contact : NiJa – 012 266 4260
Serious and interested cash buyer only
Please call for viewing the car...seldom online...TQ
