Main Forums
Car Talk
Forced Induction & Engine Management
Profec B vs Blitz SSBC spec R
<blockquote data-quote="teztozterone" data-source="post: 4316389" data-attributes="member: 29433"><p>Hi sifus, </p><p>I just bought an old gen Blitz SSBC with dual solenoid ( the controller unit only has "Hi" and "Low" display with 2 knobs to adjust , it has no boost display ) </p><p></p><p>I want to ask, between the solenoid and the controller unit, there is another control box, that has a vacuum inlet from intake manifold, which I T-off with my boost gauge.</p><p>There is also a "AC" and "WG" switch (which I assume is for you to choose whether you are running external wastegate, or normal actuator...I chose "WG" as I'm running external WG )...There is also a "gain" adjustment screw, Will it help boost response if I adjusted the screw clock wise?</p><p></p><p>I can't find a manual for this EBC, so any help is much appreciated :)</p><p></p><p>Thanks all</p></blockquote><p></p>
[QUOTE="teztozterone, post: 4316389, member: 29433"] Hi sifus, I just bought an old gen Blitz SSBC with dual solenoid ( the controller unit only has "Hi" and "Low" display with 2 knobs to adjust , it has no boost display ) I want to ask, between the solenoid and the controller unit, there is another control box, that has a vacuum inlet from intake manifold, which I T-off with my boost gauge. There is also a "AC" and "WG" switch (which I assume is for you to choose whether you are running external wastegate, or normal actuator...I chose "WG" as I'm running external WG )...There is also a "gain" adjustment screw, Will it help boost response if I adjusted the screw clock wise? I can't find a manual for this EBC, so any help is much appreciated :) Thanks all [/QUOTE]
david tao
How to adjust height for TEIN Super Wagon absorbers- ANE11W
:stupid:
As the title given,
I wonder how to adjust the height of the absorbers. I hope to lower my car just enough for my daily driving.
I have browsed the forum and read through but...
Microtech LT 10 s + XB 4 rx7 fc3s for sale
Dear all,
Thinking of selling my LT10 s x XB 4 igniter .Ard 6 months old.Reason being selling car soon ,converted my engine to stock half cut mode.:)
bought it from Vazmazz at 3.2k rm ,please anyone interested can...
Weird sound on my car T_T
any altezza owner have the sound like krok krok krok ??
when i stop the car..then i tekan minyak lagi..got a sound "krokrkorkorkrokrok" dunno comes out from where..it seems like from console box..but i guess not...
Main Forums
Car Talk
