How to adjust height for TEIN Super Wagon absorbers- ANE11W
Zombiemonkey
Kuching
:confused::confused::stupid:
As the title given,
I wonder how to adjust the height of the absorbers. I hope to lower my car just enough for my daily driving.
I have browsed the forum and read through but unfortunately I couldnt really understand, especially about the ring thingy.
How to adjust the height for TEIN Super Wagon absorbers- ANE11W. It's something like this:
there is no ring at the bottom-thread :confused:
Thanks.
thanks for quick response. so meaning i will be messing wit the spring standard rate?
what is the meaning of "pu/option" in the table?
You will Not be messing with the spring rate just preloading it more to increase the height and less to decrease it. The teins super soft ooppss... Super street is not independent ride height adjustable. Need to use the springs to adjust the height.
Let me get this DIY right
I will not be messing wit the rate? even if I turn the rings up?
Turning the rings up means lowering the car....right?
again.....what is the meaning of the column: up/ option ?
thanks
thanks
there are two rings basically in an adjustables:
  1. One for adjusting the height
  2. One for locking the height
Turning it down for lowering the car, and you need a pair of these to do it :)
http://img.directindustry.com/images_di/photo-m2/adjustable-spanner-wrench-432555.jpg
tein wagon used into SM4...
rear side cannot adjust anymore...
but still got 3 finger gap...
with 50 17" tyre series...
what is the better solution...
cut or compress the spring...
thanks
You're not actually compressing the springs when you lower the car. So you don't turn the rings (spring perches) up but down. Think of it as releasing to lower and tightening to raise. first you turn the bottom perch to indicate how much you want to go down (a gap will show), then you turn the upper perch to match the bottom perch to lock them.
You should be more worried about messing with the suspension travel. too high or too low, you'll be sacrificing ride performance. there's a set amount of travel in the shock, so going too low, you'll miss the sweet spot entirely and end up with a galloping ride.
I've not tried the Wagon spec but had the Tein Super Street for a couple of months on the MINI cooper s and it was great at normal height (2-3 fingers gap), comfortable and all, but it wasn't the firmness i was looking for. It got worse when i lowered it down to less than a finger which was what i was used to running on the Bilstein PSS9.
So most coilovers are okay to run at reasonable low ride height but not slammed.
looks like your set wasn't meant to go as low as you'd want it go. either that or it has the wrong springs. If you want to experiment, try looking for shorter, used springs in that diameter.
Hello everyone,
quick question:
what does it mean by Ft:-45 to -25, Rr:-30 to -10
for example does it mean i can adjust the front by measuring from bottom ring to thread? meaning to say (from bottom ring to thread) 4.5cm highest and lowest 2.5?
thank yous
almost done...!
