POLO GTi 1.8T 2008 9N3
Sujith
The Price is negotiable...
whatsapp +919845305568
call or message +60173506913
The car is 2008 model and ever since, the car has been regularly maintained by VW/Audi specialist at every 7.5k kms intervals and mildly modded for good pocket rocket experience. Last dyno session, it's pulling 205hp and 305 nm on wheels, see attached images.
Manual Transmission
Selling as I am relocating. While I'm putting this ad hoping to find buyer but honestly speaking I won't budge for low ballers, not in a hurry either. Kindly give me a call should you're serious about it. Thanks.
Recently done with major servicing.
http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10940 http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10939 http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10938 http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10937 http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10936 http://www.zerotohundred.com/newforums/picture.php?albumid=3201&pictureid=10935
Engine
Stock VAG BJX 1.8T 20V
1781cc in-line 4, 81mmx86.4mm
9.5:1 compression ratio
Cast aluminium alloy cylinder head
Grey cast iron blocks
81mm Mahle forged aluminium alloy pistons
Fracture-split forged steel connecting rods
Borg Warner K03S turbo (new)
Mitsubishi Lancer Evo3 intercooler (500mmx300mmx65mm) with all new custom piping
VF Engineering Race Bypass Valve (relocated)
Wahle 80deg thermostat
K&N open-pod filter with heatshield
Timing belt, tensioner damper & waterpump (new)
FrankenTurbo F21T kit 300bhp (optional)
Exhaust System
Custom 2.5” catless downpipe
Custom 2.5” exhaust piping
Stock muffler
Blitz Spec Nur muffler (optional)
Electronics/Engine Management
Bosch Motronic ME 7.5
Direct Ignition with individual direct-acting coils
VW 300cc fuel injectors
VW 4bar fuel regulator
Unitronic Stg 1+ Reflashed
NGK BKR7E (0.028 gap) copper plugs
Genesis 415cc injectors (Optional)
Transmission & Drivetrains
VAG 02R 5-speed manual
ECS Stg 1 Clutch Kit (new)
ECS Single-mass 14lbs flywheel
Suspension
H&R Monotube Coilovers
Seat Ibiza solid-rubber front bushings
Ford Mondeo’s ARB links
ECS PU rear axle bushing kit
Chassis Setup by Faidzil Alang of FA Racing
Brakes
Front: VW 312mm x 25mm vented rotors
Front: Single pot ATE 54mm calipers
Front: EBC Red Stuff pads
Rear: VW 232mm x 9mm solid slotted rotors
Rear: Single pot Lucas 38mm calipers
Rear: EBC Red Stuff pads
ECS Steel braided lines
Wheels & Tyres
Wedsport SA70 17x7.5 rims
Federal 595 RSR 215/45/17 tyres
Dyno tests:
178.57whp/253.67nm on wheels at GT Auto (25/10/2008)
174.6whp/288.7nm on wheels at Mil lennium Motorsport Sunway (10/12/2010)
216.40whp/326.97nm on wheels at GT Auto (16/07/2011)
205.13whp/304.5nm on wheels at GT Auto (19/08/2011)
Re: POLO GTi 1.8T 2008 9N3 - Dyno
Dyno Pic
The legendary Pocong GTi.
Drove with the previous owner up UYGTJ and I can tell you that this car is fast!
you are right buddy this car is not just fast.. really fast,, only reason i have put this for sale because i am relocating,,
