Plug Coil Problem
mag9556
2,000 RPM
Dear All,
Hope that someone can assist me on this as my car is using independent plug coil (coil on each plug). The problem is when ever i start to accelerate the plug coil will explode no matter how many boost I have set (even 0.5bar also the same). I have change 2sets of coil as I though is the coil problem but currently I am using new coil yet still the same problem.. Is it the ECU problem whom cause all this kind of thing?
I have start to headache hope some can assist me on my problem as keep on like this my poket will koyak oh. :retarded:
mag9556,
Bro, you did not mention what engine or car you are using.
Is it stock ecu.
For your story, you are driving Toyota Vios or Myvi which is upgrade to bolt on turbo.
If yes, i also think that you are using piggy pack euc like e-management, "The Blue" or may be others brand.
If yes, i thing to much charge ( ms ) or dwell ( angle ) on the ignitor which is buit inside the coil.
Because to much of charge, the "heat" will destroy the igitor.
Just reduce the charge to normal.
Good Luck.
:mouth_closed: actually i just brought the car.. hehe..
its rb20turbo... in cefiro a31...:_:
totally stock as engine just put in...
mag9556,
Oh..oh....Sorry to inform you....Yes, i heard a lot of complain on this model,RB20T.
Yes, it burn the coil and not the ignitor.
So, i have to ask some Si Fu for this, see got any help there.
Good Luck.
awaiting for your soonest reply with thousand thanks...
make sure your spark plug and plug cable is in good condition.problem from the spark plug and plug cable will spoil a good coil
another thing is earthing,earth the valve cover or near the coil area
Bro,
Thanks a lot will try to do it and revert the outcome...
ah.. this time my rb is safe..
Bro evo,
I have tried to change to coil and plug as well as check the plug cable but the sad things is the problem still the same..hehe..
Dun know wht to do and start mad liao set the boost to 1.2bar..
1.2bar ok aready but when at 0.4 to 0.5 bar car slightly jerk a bit after that very power oh!!
Bro ECU,
Can this be the ECU problem ah? please advice?
Hope that anyone whom face this b4 can advice me..
hehe..
mag9556,
Bro, i wonder which RB20T you have now!
You mention on "plug cable", i think the spark coils is plug on top of ecch cylinder.( of cause, plug on the spark plug ).
If this engine have plug cable, that mean you have "old" RB20T, right ?
Please confirm.
Good Luck.
hehe.. sorry ya.. not cable but wire only...
it is independent coil on each plug means the engine got 6coil..
but the wire still ok..
