Phenix Digital Canbus Slim Ballast HID Xenon Kit
Over Boost - Motorsports
Beyond 20,000 RPM!
Bandar Sunway
- Designed for maximum performance, reliability, protection and visilbility
- Available in Black color ballast only
- High quality inner materials and super slim compact ballast and lightweight
- Internals are all high quality USA and Germany microchips, IC, TI, IR and Taiwan PCB Board and UTC
- Main Technical Parameter of HID Xenon Lamp Ballast:
Input Voltage:DC9-16V
typical Voltage:DC13.2V
typical current:3.2A
Steady Power: 35W+2W
Max input current:6A
Starting up Instant Voltage: 23000V+-
Electric Efficiency >98%+
operating Temperature: -40℃--+115℃
Storage Temperature::-55℃--+125℃
Useful Life >3000Hour
- Bulbs are high density Phillips high quality UV cut glass and maximum luminous flux ≥3300LM and lifespan of up to ≥3000 hour
- Available temperature colors are 3000k, 4300k, 5000k, 6000k, 8000k and 10000k
- Available bulb types are H1, H3, H4-1, H4-hilo magnetic, H7, H9, H10, H11, H13, 9005, 9006, 9007, D2R and D2S
- Comes with nice aluminum black color case with mounting and all necessary components
- 1 year warranty on manufacturing defects
Over Boost - Motorsports are Sole Authorized Distributor and Authorized Import Agent for Phenix Digital HID Xenon Kit System
PRICE
Phenix Digital Canbus Slim Ballast HID Xenon Kit Single Beam Bulb = RM 299
Phenix Digital Canbus Slim Ballast HID Xenon Kit Moveable Bulb = RM 349
Phenix Digital Canbus Slim Ballast HID Xenon 1 Pair Ballast Only = RM 149
Phenix Digital Canbus Slim Ballast HID Xenon 1 Pair Bulb Only = RM 149
http://www.overboost-motorsports.com/zthlogo.gif
CONTACT DETAILS
Address - No 28A, First Floor, Jalan PJS 11/7, Bandar Sunway, 46150, Petaling Jaya, Selangor, Malaysia (same row as N1 Racing, beside WRC Lighting)
E-Mail - [COLOR="Black"][email protected][/COLOR]
Tel - +603-5611 6628
Mobile - +6012-955 1800
Blackberry Pin - 2284DEF5
Website - OVER BOOST - MOTORSPORTS
MSN - [COLOR="black"][email protected][/COLOR]
Skype ID - overboost-motorsports
Facebook - Over Boost - Motorsports | Facebook
Mudah - PRO Niaga: Over Boost - Motorsports
CLICK HERE FOR CONTACT FORM
What are the difference between these 4?
i'm planning to use HID for driving (4300K, H7) and for my fog lamp (6000K/8000K, 881) for my proton savvy. any suggestion on which to buy? and price? inclusive installation?
Hi Mate,
Single beam meaning there is no highlight with it, moveable kit meaning both hi-lo is HID.
RM149 is either for just a pair of ballast or the bulb, for replacement ;)
Anyways, you got PM mate, tq :biggrin:
Hi bro, its a kind of bulb where its able to supply low beam and high beam using the same bulb, mostly used in H4 and 9007, bulbs move using magnetic. Thanks bro
Bump!
---------- Post added at 11:18 AM ---------- 6 hour anti-bump limit - Previous post was at 11:12 AM ----------
Bump!
---------- Post added at 11:23 AM ---------- 6 hour anti-bump limit - Previous post was at 11:18 AM ----------
Bump!
Hi mate,
yes it can be use with most European cars which have a problem with the engine check light coming out when installing aftermarket hid kits.
Anyways currently we are using a new type that we had established with 2 years warranty and its 55 Watts AC Type current and UV Cut lighting.
More info please check it out here mate - http://www.mudah.my/Digital+Direct+HID+System+Canbus+AC+Type+55+Watts-14946329.htm
Thanks mate,
Hi mate,
Thanks mate,
bro. mind checking audi tt 2007 mk2 uk spec. using which bulb. plus send to penang. this it the slim type rite?
Hi mate,
The one we have are not slim type mate, we did not bring in the slim type anymore due to its compressed type of ballast which produce a lot of heat and with the canbus and cancellor built in, the ballast is slightly thicker.
I had check and seems to be H7, however we could not double confirm this. I would advice you to check with your workshop on the bulb type. However if you were to get the wrong one, send us back and we will exchange it for you within 1 week.
Total - RM 410 including shipping mate via Skynet Express.
Thanks mate, :)
Hi buddy,
that is just for the ballast mate, you meant this one right? - http://www.overboost-motorsports.com/product-600083.html
Anyways please note that this phenix HID kit we are not bringing in anymore. Thanks mate
