Pedders PU Bushing Available here!
Zyle
Johor
Pedders Bushing
NO BULL
HONDA ACCORD '03 PCS
RR CONTROL ARM - UPPER CAMBER ADJUSTER 2
RR CONTROL ARM 2
HONDA CIVIC EG/EK/INTEGRA DC2
FF UPPER ARM CAMBER/CASTER ADJ 1
FF CONTROL ARM - LOWER INNER 4
FF CONTROL ARM - LOWER INNER 8
FF CONTROL ARM - UPPER INNER ('[91-'01) 4
FF CONTROL ARM - UPPER INNER ('95-'01 EK) 2
FF SWAY BAR - LINK 8
FF SWAY BAR - MOUNT 18MM 2
FF SWAY BAR LINK BALL/BALL TYPE 2
FF SWAY BAR LINK BALL/BALL TYPE - VTEC 2
FF SWAY BAR LINK BALL/BALL TYPE - MULTI LINK 2
RR UPPER ARM CAMBER ADJ. 1
RR LOWER ARM - FF INNER & OUTER 4
RR LOWER ARM - LOWER INNER & OUTER 8
RR LOWER ARM - UPPER INNER & OUTER 4
RR TRAILING ARM - CENTER PIVOT(0D 80MM) FF OF ARM 2
RR TRAILING ARM - CENTER PIVOT(0D 85MM) FF OF ARM 2
RR TRAILING ARM - REPLACEMENT BUSH FOR EP7179 2
RR TRAILING ARM - REPLACEMENT BUSH FOR EP7280 2
HONDA JAZZ GD
FF CONTROL ARM - LOWER INNER FF 2
FF CONTROL ARM - LOWER INNER RR 2
KIA CARNIVAL
FF RADIUS ROD 2
MITSUBISHI GALANT HJ
FF CONTROL ARM -LOWER INNER FF 2
FF CONTROL ARM -LOWER INNER RR 2
FF CONTROL ARM - UPPER INNER 2
FFT SWAY BAR LINK 2
RR CONTROL ARM - LOWER OUTER 4
RR CONTROL ARM - UPPER OUTER 2
MITSUBISHI LANCER CJ '07 ON
FF CONTROL ARM - LOWER INNER RR (CJ ONLY) 2
MITSUBISHI EVO 1/2/3
FF CONTROL ARM - LOWER INNER FF 4
FF CONTROL ARM - LOWER INNER RR STD 2
FF CONTROL ARM - LOWER INNER RR RH STD & LH ADJ 2
FF CONTROL ARM - LOWER INNER RR RH & LH ADJ 2
FF SWAY BAR - MOUNT 19MM 2
FF SWAY BAR - MOUNT 22MM 2
RR LOWER ARM (EVO 3 - INNER & OUTER) 8
RR UPPER ARM CAMBER (EVO 3 - INNER) 4
RR UPPER ARM CAMBER (EVO 3 - OUTER) 4
RR TRAILING ARM EVO 3 4
MITSUBISHI EVO 4/5/6 PCS
FF SWAY BAR - MOUNT 17MM 2
RR LOWER ARM OUTER 4
RR LOWER ARM INNER 4
MITSUBISHI LANCER EV0 7/8/9
RR SWAY BAR LINK BALL TO BALL STYLE, MUST CUT TO 150MM 2
RR SWAY BAR BUSHH 22MM 2
MITSUBISHI LANCER EV0 10
NISSAN CEFIRO A32
FF CONTROL ARM - LOWER INNER RR LH-ADJ, RH-STD 2
RR CONTROL ARM - INNER & OUTER 2
NISSAN FAIRLADY Z350
FF CONTROL ARM - LWR INNER 2
FF CONTROL ARM - UPR INNER 2
FF STRUT BAR-TO CHASSIS 2
RR SUBFRAME MOUNT 2
RR LATERAL ARM LOWER INNER 2
RR LATERAL ARM LOWER UPPER 2
RR LATERAL ARM UPPER INNER 2
RR TRAILING ARM LOWER FF 2
RR TRAILING ARM LOWER RR 2
RR TRAILING ARM UPPER FF 2
RR TRAILING ARM UPPER RR 2
NISSAN SENTRA N16
FF CONTROL ARM - LOWER INNER RR 1 SIDE ADJ 2
FF CONTROL ARM - LOWER INNER RR LH & RH ADJ 2
FF SWAY BAR LINK 2
NISSAN SILVIA S14/S15
FF CONTROL ARM - LWR INNER FF 70MM OFFESET CASTER 2
FF CONTROL ARM - LWR INNER FF 70MM (ALTER LH) 2
FF RADIUS ROD 70MM & BRACKET 40MM WIDE 2
FF SWAY BAR - LINK (S14) 8
FF SWAY BAR - MOUNT (S14) 2
RR SWAY BAR - LINK (S14) 8
RR CROSSMEMBER BUSH 2
NISSAN SKYLINE R34 2WD/GTR PCS
FF CONTROL ARM - LWR INNER FF 70MM BOTH OFFSET 2
FF CONTROL ARM - LWR INNER FF 84MM BOTH OFFSET 2
FF CONTROL ARM - LWR INNER FF 70MM 1 STD & 1 OFFSET 2
FF RADIUS ROD 70MM 2
FF RADIUS ROD 84MM 2
RR SWAY BAR - LINK 2
RR SWAY BAR -MOUNT 2
RR LOWER ARM - INNER 2
RR UPPER ARM - INNER & OUTER 8
RR UPPER ARM - OUTER 2
RR CROSSMEMBER BUSHES X-MEMBER 2
RR CROSSMEMBER BUSHES DIFF-MOUNT 2
RR CROSSMEMBER BUSHES DIFF-MOUNT INSERT 2
NISSAN SKYLINE R33 GTR
RR LATERAL ARM LWR 2
RR LATERAL ARM UPR INNER 8
RR LATERAL ARM UPR OUTER 2
NISSAN X-TRAIL
FF CONTROL ARM - LWR INNER FF 2
FF CONTROL ARM - LWR INNER RR STD 2
FF CONTROL ARM - LWR INNER RR LH ADJ & RH STD 2
RR CONTROL ARM RR INNER & OUTER 2
PROTON WIR/WAJA
FF STEERING RACK MOUNT 2
RR CONTRL ARM LOWER INNER & OUTER 4
RR UPPER ARM CAMBER INNER 2
RR UPPER ARM CAMBER OUTER 2
RR TRAILING ARM FRONT 2
RR TRAILING ARM OUTER 2
RR TRAILING ARM INNER 2
RR LOWER INNER & OUTER (WAJA) 4
SUZUKI SWIFT '05 PCS
FF CONTROL ARM - LWR INNER RR - STD 2
FF CONTROL ARM - LWR INNER RR - RH STD & LH ADJ. 2
FF SWAY BAR MOUNT 2
TOYOTA ATLIS
FF STABILIZER LINK 2
FF SWAY BAR LINK 2
FF SWAY BAR MOUNT 2
RR STABILIZER LINK 2
RR TRAILING ARM LWR 2
TOYOTA CAMRY ACV40
FF CONTROL ARM - LWR INNER RR 2
FF SWAY BAR MOUNT 2
RR TRAILING ARM -LWR 2
RR LATERAL ARM -LWR FF 2
RR LATERAL ARM -LWR RR 2
FF SWAY BAR MOUNT 2
TOYOTA CAMRY ACV36 '02 ON
FF CONTROL ARM - LWR INNER FF REUSE ORI. MOUNTING PIN 2
FF CONTROL ARM - LWR INNER RR - RH & LH ADJ. 2
FF CONTROL ARM - REPLACEMENT BUSH FOR EP6327 2
FF STABILIZER LINK - MULTI FIT LINK 2
FF SWAY BAR MOUNT 17MM 2
RR STABILIZER LINK - MULTI FIT LINK 2
RR SWAY BAR MOUNT BUSH 2
RR LOWER ARM BUSH 8
TOYOTA CAMRY CV20 '97
FF STABILIZER LINK -LH 2
FF STABILIZER LINK -RH 2
FF STEERING RACK MOUNT - D 3
FF STEERING RACK MOUNT - ROUND 2
FF SWAY BAR MOUNT 15MM 2
FF SWAY BAR MOUNT 16.5MM 2
FF SWAY BAR MOUNT - 17MM 2
RR SWAY BAR MOUNT - 16MM 2
RR LOWER ARM BUSH 8
TOYOTA CELICA '99 ZZT231
RR SWAY BAR MOUNT - 14MM 2
RR LOWER ARM BUSH 8
TOYOTA COROLLA AE101/111 PCS
FF CONTROL ARM - LWR INNER FF 4
FF CONTROL ARM - LWR INNER RR HORIZONTALLY 92-93 2
FF CONTROL ARM - LWR INNER RR VERTICALLY '94 ON 2
RR STABILIZER LINK '95 0N 2
RR LOWER ARM BUSH 8
TOYOTA COROLLA AE 92
FF CONTROL ARM - LWR INNER RR LH-ADJ, RH-STD 2
FF CONTROL ARM - LWR INNER RR LH & RH ADJ 2
FF SWAY BAR MOUNT - 24MM 2
RR LOWER ARM BUSH 8
TOYOTA COROLLA AE 86
FF CONTROL ARM - LWR INNER 4
FF SWAY BAR MOUNT 2
FF RADIUS ROD 2
RR SWAY BAR LINK LOWER LINK PIN 2
RR SWAY BAR LINK UPPER MOUNT 2
RR PANHARD ROD TO CHASSIS 2
RR PANHARD ROD TO DIFF 2
TOYOTA ESTIMA '00 ACR 30
TOYOTA ESTIMA '06 ACR50
TOYOTA HARRIER RX330
TOYOTA RAV 4 '00
FF SWAY BAR MOUNT BUSH 2
TOYOTA SUPRA '93 PCS
FF CONTROL ARM - LOWER INNER RR LH-ADJ, RH-STD 4
FF CONTROL ARM - LOWER INNER RR LH & RH ADJ 4
RR CONTROL ARM - UPPER ARM 2
RR TRAILING ARM 2
RR LOWER ARM FF 2
RR LOWER ARM RR 2
TOYOTA NEW VIOS/YARIS '08
TOYOTA VIOS
BMW E36 318i/320i/325i/328i
FF CONTROL ARM - LOWER INNER RR 4
FF RADIUS ROD BUSH 2
FF SWAY BAR MOUNT BUSH 20MM 2
FF SWAY BAR MOUNT BUSH 22.5MM 2
FF SWAY BAR MOUNT BUSH 23.5MM 2
FFSWAY BAR MOUNT BUSH 24MM 2
FF SWAY BAR MOUNT BUSH 24MM 2
FF SWAY BAR MOUNT BUSH 26MM (M3) 2
RR SWAY BAR MOUNT BUSH 15MM 2
RR SWAY BAR MOUNT BUSH 17MM 2
RR SWAY BAR MOUNT BUSH 18MM 2
RR SWAY BAR MOUNT BUSH 19MM 2
RR SWAY BAR MOUNT BUSH 20MM 2
RR TRAILING ARM - UPPER INNER 4
RR TRAILING ARM - FF 4
RR LOWER ARM 4
BMW E46 318i/320i325i/328i
FF CONTROL ARM - RR 60MM 4
FF CONTROL ARM - RR 66MM 4
FF CONTROL ARM - LOWER INNER RR 60MM 4
FFT CONTROL ARM - LOWER INNER RR 66MM 4
RR TRAILING ARM - FRONT 4
RR LOWER ARM 4
BMW E34 520i/525i PCS
FF SWAY BAR MOUNT BUSH 15MM 2
FF SWAY BAR MOUNT BUSH 17MM 2
FF SWAY BAR MOUNT BUSH 18MM 2
RR SWAY BAR MOUNT BUSH 16MM 2
RR SWAY BAR MOUNT BUSH 14.5MM 2
VOLKSWAGEN GOLF MK5
FF CONTROL ARM LOWER INNER FF 2
FF CONTROL ARM LOWER INNER RR 2
FF STEERING RACK 2
RR TRAILING ARM FF 2
VOLKSWAGEN GOLF MK6
FF STABILIZER LINK RHS 2
FF STABILIZER LINK MULTI FIT LINK 2
RAR SWAY BAR LINK 2
RR PANHARD ROD (LIVE REAR) 2
TOYOTA RAV 4 '00
RR TRAILING ARM 2
RR LOWER ARM FF 2
RR LOWER ARM RR 2
TOYOTA VIOS
RR LOWER ARM 4
RR LOWER ARM 4
VOLKSWAGEN GOLF MK5
FF STEERING RACK 2
VOLKSWAGEN GOLF MK6
Contact me for more info !!
0197122752
website: Pedders Suspension Johor
facebook: www.facebook.com/tjm4wd
Hi there, could you PM me the prices for Vios '07. This is not the '03-'06 Year make right?
  • FF CONTROL ARM - LWR INNER FF 2
  • FF CONTROL ARM - LWR INNER RR - STD 2
  • FF CONTROL ARM - LWR INNER RR - RH STD & LH ADJ. 2
Delivery to KL or do you have a disti here?
Thanks!
Yup this is for the newer model .
Yup we can deliver to kl
PM me whole set for Toyota Vios 2003
Great interested here
Up for bushing!!
---------- Post added at 12:52 AM ---------- 6 hour anti-bump limit - Previous post was at 12:52 AM ----------
Up for bushing
