4EFTE and 4AGZE is same, i plug and play both of them on my car before, nothing much different.....should be 0.9 is the maximum maybe only 0.88 or 0.87 already boost cut!!!
I see...lets say if I want to rise up the boost to around 18-20psi, instead of using the bleed valve to trick the ECU, is there any other MAP sensor I can use...?
dun use FCD la.. no good.. it will keep the signal to ecu is 0.9bar to avoid boost cut. easy to blew engine le if u dun have aditional injector tuned right
i will go for AFM for my 86 soon, i got the ecu and air flow already. juz no time to do it yet
Ok guys I got plans to do up this old ride of mine actually can consider family car coz it's parked at the home most of the time as we got our rides. It's a Mitsubishi Lancer MX year 1997 1.5 DOHC triptonic no rust...
