Nissan Skyline GT-T Tuning - GUIDE
sakuraguy
5,000 RPM
Sendai, JAPAN.
STAGE 1
Under the hood (stock 140 to 150rwkw)
The R34 GTT replaced the Nissan Skyline R33 GTS25T and features a upgraded version of the RB25DET. The main difference is the NEO head which has a new varible valve timing system, revised cam profiles, and solid lifters. Power was increased to 206kw with more torque availible earlier in the rev range. The turbo has a slightly larger exaust housing and a nylon compressor wheel. Cooling has also been improved with a larger more efficent intercooler.
Engine Tuning Stage 1
Exhaust (around 160rwkw)
The RB25DET NEO is a sweet sounding engine but very quiet in standard form and as with most factory turbo cars the exhaust causes a huge restriction. A good free flowing exhaust will have the RB sounding great, turbo lag will be reduced, and power gained throughout the rev range. The new exhaust should start from the turbo with a dump pipe either a 3" open bell mouth or better still a split dump to separate the gases from the turbine and wastegate. From here a high quality 3" high flow cat should be used, then 3" all the way to the back of the car with high flow mufflers.
Intake (160 to 170rwkw)
Now we have the exhaust side of the engine breathing the next step is to get more air into the engine. Either use a high performance air filter, or replace the air box with a POD style air filter. If you choose to go the POD filter route I recommend you fabricate some type of shield to keep hot air from the engine bay away from your intake. A cold air intake to the filter from the front of your Skyline will also give you a performance advantage. 5-10 rwkw is achievable with this mod.
Boost increase (175 to 185rwkw)
In standard form the R34 runs a two stage boost control system 5psi to 4500 rpm then 7psi to red line 7000 rpm. As mentioned before the turbo’s exhaust wheel is ceramic and they tend to fail if to much heat is generated. The amount of boost you can run with the stock turbo is debatable but I don’t recommend running more than 10 psi. You have a few options when choosing to increase the boost either a manual boost controller, electronic boost controller, or a new wastegate actuator.
A manual controller is very basic in its operation it bleeds off air causing the wastegate actuator to open later. The amount of boost run depends on the amount of air bled form the system. It is critical to install an after market boost gauge before carrying out this modification as the stock gauge is not accurate enough and is measured in mmg not psi or bar. Manual boost controllers are cheep and easy to install but they do have there disadvantages some can cause boost spikes and boost creep I have also found boost tends to tail off high in the rev range.
Electronic boost controllers on the other hand use stepper motors and monitor boost about every 10th of a second because of this boost spikes and boost creep are kept to a minimum, and the desired boost level is held to redline. Electronic boost controllers are expensive and for this level of modification a manual controller will probably be good enough.
A 3rd option is to install a different wastgate actuator and the good news is the R32GTST item is exactly the same as the R34 except the spring inside is set for 10psi. R32 actuators can be hard to find but I think it’s the best option for this level of modification as boost spikes and boost creep are eliminated.
No mater which system you choose the 2 stage boost control system should be disconnected. After this mod is carried out many people notice flat spots throughout the rev range this is due to the ECU seeing an increase in airflow and as a safety precaution it richens the air fuel mixtures. Many people find re-gaping the spark plugs from 1.1mm to 0.8mm fixes this problem but if it does not you need to consider the next upgrade.
ECU (185 to 200+rwkw)
As mentioned before many people have problems with flat spots and rich air fuel ratios. Even if you don’t have these dreaded flat spots an aftermarket ECU will give good power gains and improve drivability. One popular option is the Apexi SAFC (Super air flow computer). The SAFC is a piggy back to the ECU and works by tricking the ECU into thinking your engine is getting more or less air than your engine actually is. Tuning should be done be a professional on a dyno this modification should fix those dreaded flat spots by leaning you airfuel ratio's at different RPM points.
A better but more expensive option is the Apexi Power FC which replaces the standard ECU. Many people choose the Power FC as its less expensive than other aftermarket ECU's, and it plugs straight into you old loom so there is no need to cut any wires. All parameters of your car can be tuned with a Power FC but once again it should be dyno tuned by a professional. Please note the power FC cannot be used an automatic transmission.
Clutch and Fuel Pump At this level of modification it’s likely that your clutch and or fuel pump will need upgrading to handing the extra power.
Conclusion
This completes stage 1 engine tuning for the Nissan Skyline R34 GTT. Basically at this stage we are at the limits of the standard turbo and fuel systems but in terms of car modification this level of tuning offers great value for money. Many people with these modifications along with well sorted suspension and tyre packages have 12 run second quarter mile passes.
STAGE 2
Engine Tuning Stage 2
Stage 2 of tuning is where things start to get expensive as we need to upgrade many of the standard systems. Nissan Skyline RB engines are known for the strength the RB25 is no exception with regular maintenance and a safe tune 270rwkw is easily possible. Some people push the limits with 300rwkw+ but if you want an engine that will last 270rwkw is a safer limit.
Turbo Selection
There are many good turbo options available but I recommend a turbo that will bolt onto standard manifold this will save time and money in the long run. Many people in Australia have had there standard Nissan Skyline turbo high-flowed by GCG turbo’s these turbos are popular because they use a ball bearing cartridge, and everything bolts back into place. Turbo response is said to be similar to stock and power figures average around 230rwkw or up to 250rwkw with cams. Some people have used larger exhaust housings from the R34 GTT or the old single turbo 300zx and have achieved 270rwkw+.
HKS in Japan have a range of turbo's for the R33 that come with all the parts needed to bolt on. Suitable kits available from HKS at the moment include the HKS GT-RS known to make 280rwkw and the HKS PRO-S known to make around 300rwkw the GTRS is cheaper and a little more responsive than the PRO-S. Another popular choice since superseded by newer models was the 2535 which is similar to the GT-RS.
Intercooler Upgrade
The standard R34 Nissan Skyline intercooler runs out of its efficiency range at power levels above 200rwkw and needs to be replaced by a larger front mounted intercooler. GTR intercoolers are a popular choice but custom piping will be needed in order for it to fit. Many aftermarket bolt on kits are available for the GTT these days starting at around AU$500 but as with most things you get what you pay for. Be aware a small decrease in throttle response may be noticeable due to the extra piping and larger core size. You may notice a small increase in power with this mod before upgrading your turbo as airflow will increase and the air will be denser.
Fuel system
If you haven’t done so already the fuel pump will need to be upgraded. Second hand GTR pumps are a popular option as are new pumps from bosch, walbro, and tomei. The GTR and Tomei pumps are a direct fit. You may also install a fuel pressure regulator to increase fuel pressure.
Standard injectors will also need to be upgraded at this stage. You can either have your standard injectors high-flowed, or buy after market ones from Nismo or Performance company's. I recommend you use injectors that are a direct replacement and don’t require any modifications s to fit.
To improve the tunability of the engine its a good idea to upgrade your airflow meter this allows for finer tuning which will result in smoother power delivery and make it easier for the tuner to produce a higher peak power output . Popular upgrade choices include the Z32 and the Q45. The Z32 is cheaper of the 2 but the Q45 will allow more airflow.
Airflow meters
How they work
Air is measured using a sensor and this value is converted to a voltage which the ECU see's. For example 4 volts is the measured at idol and 12v measured at full thottle (im not sure what the actual values are). Engines are tuned by using both the airflow meter and engine RPM.
Rule of thumb for Air Flow meters maximum power they can messure
Number of AFMS 1 2
RB26 149 299 65mm
RB20/RB25 226 453 80mm
Z32 255 511 80mm
Q45 302 605 90mm
Airflow-meters alow more presice tuning but you can still tune your engine when exeeding flow limits by using the RPM scale. For example you could use a single Z32 AFM for a engine producing over 300rwkw
ECU
If you have not done so already the ECU will need to be upgraded even with a SAFC or similar the stock ECU will not do the job. As stated before the Power FC is a popular option due to its price, ease of installation, and use. There are plenty of other options that are superior to the Power FC and allow many other tuning functions like launch control, and the ability to use a map sensor instead of the airflow meter. But the FC is still a popular and is proven to perform.
Head Gasket
Running boost levels above 1.2 may require a new metal head gasket to lower compression and improve reliability. Opinions differ on this subject so I think its best to ask you tuner.
Clutch and flywheel
The stock clutch will certainly fail quickly at this power level the hardest part is finding a clutch that will handle the power yet not make your car a pig to drive. Exeedy seem to be popular and reliable choice and while you are upgrading your clutch a lightened flywheel is well worth considering. This will help the car rev quicker but the trade off is your car will loose momentum quicker to.
Cams or Cam gears
At this stage the skyline will benefit from a set new cams, cam gears, or both. The outright power will be increased but the main reason for installing cams is for a fatter torque and power curve. Upgraded cams can help reduce lag, improve mid and top end power. Popular choice is tomei pon cams as they fit without modification and are proven to give good results.
i was thinking of upgrading my gtt.....my boost meter show 0.7 bar at most even after i modded it ...how come???i am planning to buy a wastegate and an intercooler...will tat help???
Any sifu can give some comments on how to upgrade it ??thanks thanks...ohh yeah....my baby is running everything stock.... :)
chris upgrading wor.... huiyoooh......
some more buying wastegate.....
chris should buy boost controller lah....
I would suggest u change Intercooler, boost controller, exhaust system, front pipe, turbo outlet and power FC (SAFC also will do).....NEO 320hp on wheel!!Like our fren SKAGEE car,hehehhehe......
i wanna mod gt-t auto, any recommended ecu? plan to change the exhaust and increase the boost. about the intake, auto better use ori airbox?
aha, my neighbour! recommended ecu is stock ecu but using piggyback (apexi safc or greddy emanage). dont forget front mount intercooler too. u can use whatever air filter u want.
Source - NISSANSKYLINE.6TE.NET
We all know you enjoy copying and pasting, and that there is no harm sharing but there is such a thing as plagiarism. Least you could do is quote your sources to show some respect to the person who wrote it.
GTT running nylon turbines, 0.7 bar is a safe setting before the turbines give way, although i have seen ppl running 1.0 bar for a year plus but entirely not recommended.the series 1 R33 has a better turbine but still limited at 0.8-0.86bar boost for safety purposes. Also you need ECU upgrade as the stock ECU limits your boost to 1.0 bar.
A intercooler upgrade will see a bit of horses increase but not much, depending on the thickness your boost may come early or later.
Your headgasket is only good for 1.2bar of boost, any compression higher than that equals kaboom. For you to run more than 0.7 bar,the followings are recommended:
safe boosting:
1)piggyback or complete ecu to delimit your 1.0 bar boost limit and injectors
2)injectors, cheap upgrade would be silvia injectors
3)new turbo. Subjective, depending on your future mods but a definite to replace if you wanan run more than 0.7 bar
4)turbo manifold, depending on the turbo you choose.There are alot of small turbo varieties for your stock manifold.
4)headgasket if you want to run more than 1.2bar boost.
5)fuel pump is optional but recommended since its cheap anyways.
6)GTR pistons+rings(cheap cheap)
7)intercooler.(local/china brands are cheap these days and good for 500hp, what a steal)
8)clutch (if run more than 350ps)
super budget boosting:
1)hafkat turbo that fits stock turbo manifold
2)re-chip ecu
3)wait for your stock spark plug to give u flat spots boosting
4)wait for engine to explode then overhaul.Optional to cry over parents or loan officer for rb26dett.
khoyos,
a gtr owner told me e-manage would burn my starter coil, ever heard about that? use s-afc, no prob with gearbox? front mount intercooler x lag ke? what exhaust setup is good for auto?
bikerz,
Not sure if it still happens with the newer e-manage but when I was running it with my evo 7, I fried 4-5 coils in a period of 3 months... :biggrin:
bikerz,
I'm using the emanage blue (Mutiara Motor Edition) and no problems so far... the emanage been in for over a year. BTW Greddy has an extra harness for nissan ignition, not sure if it helps but according to GT Auto it may, cost about rm150. You can also have a wire guy fit resisters to cut to voltage to the coil packs, skyline aust. forums for info.
Whichever ECU you're planning to use, pls make sure your base timing is set correctly first. Rule of the Thumb no.1
if i want to increase boost, install e-manage, but maintain ori exhaust, is it ok? coz want to maintain silent
Don’t quote me on this, but if you just increasing a little boost pressure (form 0.5 to 0.7), the stock ECU will compensate. This is true for my other Japanese cars before.
But if you want to fine tune things then go for the piggyback ECU. Of course if you plan to mod your car anyway a proper ECU is essential
change exhaust first, release the restriction. automatically it'll be more powerful without even increasing boost. there are many types of silent exhaust systems out there...
hi sifu,
just wanna know..what is the max hp can i gain with er34 auto box?
