- Joined
- May 26, 2006
- Messages
- 775
- Points
- 1,518
My objective is simple...
To get the ceffy to take corners as well as any stock rear independent suspension vehicle, or at least, come bloody close to it...
The ceffy suffers from a host of problems caused by :
a) The rear torsion bar
b) The length of the wheelbase
Taking corners on stock suspension basically feels like a boat. Lowering springs like Eibach basically lower the centre of gravity and loads up the absorbers thereby making the suspension stiffer, but the effect is still far from desired.
Even on the Hotbits set I have, the handling is much better overall, but I have significantly compromised it's comfort.
Then, as the ceffy ages, and the metal shell degrades, you start getting all sorts of creaks and noises. Noise does not happen unless there is movement somewhere in the car. Because of the long wheelbase, every time you take a corner, the body flexes...resulting in bad weight transfer which lowers the efficiency of your absorbers and springs, irrespective of the type of absorbers adn springs you may be using, plus, creaks as the metal welding points flex.
So...my next mod will take care of all this. I expect to be able to handle corners almost like a beamer, and certainly much better than a stock A33. And, I will eliminate a heck of a lot of irritating noises. My absorbers and springs will be fully optimized, and I won't get sea-sick every time I go up Gentings...
The best part is...even on stock springs and suspension, your handling is going to be so good, you might decide not to spend that RM 3k+ on aftermarket coilovers or Titans...
Presenting........SUBFRAME CONNECTORS.
This is not new and has been installed in cars for a loooong time. Ultra Racing has been installing these in Perdanas and A31's. For drift cars, it is almost mandatory for a subframe connector stage II set to be installed.
There is no ready-made option available for the A32 and A33. However the principle is so simple, that any welder could fabricate one.
Subframe connectors work by stiffening up the chasis and limiting the amount of flex, which makes for more positive handling characteristics. Weight transfer is also optimized, and this will allow your suspension and springs to work the way they were meant to work.
I've called Ultra Racing, and yes, they can fabricate them for us. The price : RM 450 - 550.
BUT...this thing is so easy to do. So, why pay Ultra Racing for a few bits of metal welded together. I've been talking to Naray, and we think we may be able to get some commercial welders to do them for us.
All we need is material (Ong), welder (Naray), design (Me) and some way to lift the car on all 4 wheels (the suspension has to be loaded with the car's weight so that the body flexes into the shape it is usually in when driven before welding in the subframe connectors. An inspection bay would be best. Or, one of the old car-wash ramps but a low ramp, cos the car has to be horizontal when the welding takes place. A wheel allignment bay would also do...so maybe one Sunday at Lee's? I think I can interest him enough in the project for him to come and open his workshop doors one Sunday...
Comments please...
Comments please...
