-New- Phoenix Gold Product Range
ICE -In Car Entertainment
Sq Voicez
From Facebook
Phoenix Gold
Website - http://www.phoenixgold.com/default.aspx
R500.1 - RM1680
500 watts x 1 @ 2ohm
250 watts x 1 @ 4 ohm
R1000.1 - RM2630
1000 watts x 1 @ 1ohm
750 watts X 1 @ 2 ohm
R300.4 - RM1590
75 Watts x 4 Channel / 2 ohm
50 Watts x 4 Channel / 4 ohm
R500.4 - RM2250
125 Watts x 4 Channel / 2 ohm
75 Watts x 4 Channel / 4 ohm
Ti2500.1 - RM7500
2500 watts x 1 @ 1ohm
1500 watts x 1 @ 2 ohm
Ti1500.1 - RM5100
1500 watts x 1 @ 1ohm
1000 watts x 1 @ 2 ohm
Ti800.4 - RM4150
200 Watts x 4 Channel / 2 ohm
125 Watts x 4 Channel / 4 ohm
Ti600.4 - RM3100
150 Watts x 4 Channel / 2 ohm
100 Watts x 4 Channel / 4 ohm
S400.4 - RM2400
75 Watts x 4 Channel / 2 Ohm
50 Watts x 4 Channel / 4 Ohm
S1000.1 - RM3080
1000 Watts x 1 Channel / 1 Ohm
750 Watts x 1 Channel / 2 Ohm
The One (Limited Edition) Monoblock
THE ONE pushes the rich tradition of limited edition amplifiers to a new level. This is the most powerful amplifier Phoenix Gold has ever built, 12,000 watts RMS into a single channel. Part beast, part piece of artwork the massive internal components are visible for all to see via the plexiglass cover. Each amplifier is truly unique as the limited edition unit number is laser cut into the heatsink, so no two amplifiers are alike. Limited quantities available.
F e a t u r e s :
• 12,000w x 1 @ 1 ohm
• 8,000w x 1 @ 2 ohm
• Limited Edition Production Run
• 3 Ounce Gold Plated Circuit Board
• Six Internal Power Supplies with Hand Wound Transformers
• Temperature Controlled Fan Cooling System
• High Efficiency Class D Topology 24dB
• Detented Low Pass and Subsonic Filters
• Operates up to 16 Volts DC
• Two amps are linkable for 24,000w
S p e c i f i c a t i o n s :
Power Rating 12000 Watts x 1 Channel / 1 Ohm
8000 Watts x 1 Channel / 2 Ohm
24000 Watts x 1 Channel / 2 Ohm Strapped (2 unit linked)
Low Pass Filter 30Hz to 300Hz
Low Pass Filter Slope 24dB/Octave
Power Terminal 1/0GA
Subsonic Filter Range 10Hz to 55Hz
Bass Boost +0 to+6dB
Dimensions 12”w x 3”H x 37”L
Note: Only 25 unit made so far and currently 2 being own by Malaysian. Retail Price RM29000, CALL for best price.
2 way component
R65Comp - RM550
Ti65Comp - RM1090
Subwoofer
R1.12 (SVC) - RM410
R1.12D (DVC) - RM450 Need to order
R2.12D (DVC) - RM980 Need to order
SVC - single voice coil
DVC - double voice coil
We also carry other product like Audio Development Italy (AD Italy), AVI Sound, DEGO and XSite. PM me for more info.
Call 019-6096992
