New Perodua Model in MARCH ?
R.C.
Have anyone heard about a replacement model for Kancil / Kelisa ?
:regular_smile:
A new model from PERODUA around MARCH or so ? Maybe someone could share in this thread ?
Thanks
i also heard bout it.....maybe goin to be launch on march 2007.....
now R&D process.....
its a kelisa replacement....
based on MIRA AVY.....but malaysia ardy change the facelift looks:sad_smile:
MIRA AVY look more yummy.....same size s naza suria if im not mistaken.....:_:
this is the based model from daihatsu...Mira AVY
http://i138.photobucket.com/albums/q241/mR_hANNy/frontavy.jpg
http://i138.photobucket.com/albums/q241/mR_hANNy/rearavy.jpg
OoOo.
What would they name it ? I hope maybe Perodua Trinity since we already have Proton Satria Neo =P
The size of Myvi or Kelisa ? Looks bigger than Kelisa.
Mr Ad,
Mira Avi or Mira X? Here is some pic for you to see. The White Colour was spotted at genting.
yeah. hoping that Kelisa/ kancil replacements can shake the dull, boring auto scene on todays.
why dont they just bring in the real Mira, instead of having 'filtered' one selling over here. the old mira (which converted into kancil or whatever it is here) got fitted turbochargers and better brakes.
HTML:
[ATTACH=full]616417[/ATTACH]
jeanloo said:
Mr Ad,
Mira AVY i think...correct me if im wrong....
the blue one is the original daihatsu MIRA AVY....
the white one is the perodua one.....
bring in the real Mira as in badging it as Daihatsu Mira? Will you pay for the price or not as it sure will be a CBU... why they don't fit in turbochargers is because it is more complicated for the service centers...
Tohsan said:
how big is the size,is it more or less same size as kancil?
i think it should be taller than Kancil... not really Kancil actually...halfway between a kelisa and kenari... think it will be called Vivo or something... or is Vivo a Daihatsu name... did not bother to check the name out anyways... price should be close to 40k i suspect... engine spec i have no idea... about 1500cc in a Perodua...don't have such high hopes for it... it will not happen...so is turbocharging...
guysss..
frm da pics spotted i guess perodua did another good R&D eventhough no turbocharge.
p/s : looks more into myvi emmm...confused !
Number of seats 4
Engine
Engine code EF-DET
Engine type Otto, Front transversal
Number of cylinders 3, In-line
Engine capacity 659 cm3
Number of valves 12 DOHC
Fuel Petrol, Injection by cylinder
Supercharging Turbo + Intercooler
Bore 68.0 mm
Stroke 60.5 mm
Compression ratio 8.5
Max Power 47 kW (JIS) 6400 rpm
Max torque 103 Nm (rpm) 3200 rpm
Transmission & Drive
Drive all-wheel drive
GearBox 5 Manual
Steering type Hydraulic power
Brakes & Tyres
Front tyres 165-155/55-65R15-14
Rear tyres 165-155/55-65R15-14
Front brakes Disc
Rear brakes Drum
Suspensions
Front Suspension MacPherson strut, Coil spring
Rear Suspension Coil spring, Multi-link
Dimensions
Wheelbase 2390 mm
Length 3395 mm
Width 1475 mm
Height 1530 mm
Track (front) 1300 mm
Track (rear) 1265 mm
Curb weight 830 kg
Fuel tank 34 liter
Consumption
Average consumption 5.0 l/100 km (Werk)
Advertisement
Number of seats 4
Engine
Engine code EF-DET
Bore 2.7 in
Stroke 2.4 in
Max torque 76.0 lb-ft (rpm) 3200 rpm
GearBox 5 Manual
Brakes & Tyres
Front brakes Disc
Rear brakes Drum
Suspensions
Dimensions
Wheelbase 94.1 in
Length 133.7 in
Width 58.1 in
Height 60.2 in
Track (front) 51.2 in
Track (rear) 49.8 in
Curb weight 1830.2 lb
Fuel tank 8.8 gall.
Consumption
Average consumption 47.0 mpg (Werk)
Advertisement
The 4WD TURBO MODEL for Daihatsu Mira AVY =P
its going to be kancil n kelisa replacement model...Power-Up engine...660cc to 850cc is for kancil replacement n the same car with 1000cc is replacement for kelisa...850 n 1000cc will be complete with ABS,Airbag,Folding signal side mirror n all will have power stering...YAY!~...hehe..correct me if im wrong..got information from a friend working at Perodua R&D.....
