Car Brands
Car Manufacturers
Honda
need help-speedometer is crazy
<blockquote data-quote="ARe-BeaR" data-source="post: 735080" data-attributes="member: 8823"><p>speed sonsor located on top of the gearbox.... check light will on when it not working... stop ur car then ketat2 kan sket the socket... then should be ok... if not then change the socket coz may be it loose.... i also met the problem before.. my speed meter go down to 0km/h or freeze at what number the neddle like... hehehe...</p></blockquote><p></p>
[QUOTE="ARe-BeaR, post: 735080, member: 8823"] speed sonsor located on top of the gearbox.... check light will on when it not working... stop ur car then ketat2 kan sket the socket... then should be ok... if not then change the socket coz may be it loose.... i also met the problem before.. my speed meter go down to 0km/h or freeze at what number the neddle like... hehehe... [/QUOTE]
R35 Used Titanium Exhaust
Cam Shaft
Hi....
just wondering, if wanna change ori cam to evo8 cam what is the difference???
Thanx in advance.
How the hell do you tune Ignition Time with eManage?
Since we dont know the orginal ignition curve.....is it hit and miss?
DIY cup holder
Anybody done dis b4?? plz share yur experienc
is not a very common thing but when wanna use it, u headache(i mean me la :tongue: ), saw acc shop sellin alot of variety but seems over $$ 2me(mayb bcoz i...
Car Brands
Car Manufacturers
Honda
