need advice toinstall dohc head into satria
amal
hi all,
im currently using a 1.6 sohc satria.would like advice on how to install 4g92 dohc head into my car.can i use my current ecu?waht is a afr?pls tell me everything i would need to change in order to change my current sohc to dohc.and finally any place or mechanic that can quote me a price with installation.advice really appreciated.cheers.
thanks bro.so firstly,i have to get the 4g93 head.along with the afr.do i need anything else.eg distributor..etc.?how much is the afr?pls advice on everything i will need to get.really need advice from u guys.its a relief to be able to reuse my current ecu.can anyone quote me an estimation of the total amount along with installation?and if possible a reliable mechanic that can get it done?thx.help much appreciated.
afr is about 150+/- branded afr is about 300+/- is up to u... distributer u can use 91 carbie1... o use back 92p but u need to mod coz the 92p distributer is bigger little... but still can fit in... u need a timing tensioner... plug cable is different.. timing belt need to change then got 2 timing bearing, sohc only got 1 timing bearing, most of the stuff can use back!!!
theres a thread on it... u can find evry thing u wanna know regarding the convertion... ive done it and its cool...
It's always get best to get the complete set of head, ECU, wiring, injector, intake manifold all throw in together rather then rojak here and there..later got problem VERY hard to verify....
Just my 2 cents.
Just my 2 cents.
yes correct the most inportant thing is complete head!!
but then can use back the ecu and wiring no problem!! coz the head doen't hav any electronic stuff n wiring inside the head!! intake manifold n extractor can fit nicely...
well.. the common problem is the leaking problem.. the rest shouldn't hav any major problem.. and of coz ur mech must b good in adjusting the correct pully n correct timing belt used.. wrong timing can coz major problem!!
hey guyz i need help.....im using a wira 1.5 carbs....i wanna change the head to at least a 4g92 head ....will it fit.....my frenz are telling me to change to 4g93 but will it fit to the 1.5 block???...
nope.. nomal 1.5 / 1.3 is 4G13 an 15.. its diff from the 91/92/93 coz its from 4G9x series... unless u change the whole engine :D
bore ur block 2 the size of 1.8 o 1.6 lo...
izzit?? i think can la.. i got 1 fren bore also.. but dunno... to wut size la...
bore can.. i mean i dont think can fit DOHC head lor..
ooh... 4g1x ar?? yup.. can't mod to dohc head!!!
in japs 4g1x also single cam rite?? hmmmm... so there is no dohc head can fit in 4g1x block!!
4g15 got twincam version lor.... but it is fitted in mitsu lancer models....
but conversion from SOHC to DOHC on 4g1X engines i not sure la...
got ka?? 4g15 dohc??? havn't c b4!!!
heheheee... thanks 4 the new info 4 me!!
well... so far i havn't seen a 4g15 from sohc to dohc lo...
hey got meh the 4g15 dohc head
hey guys ive never heard b4 abt the 4g15 dohc head.....but anywayz ....any particular place that i can find the head ....kasi recomend larr brader ????......usually how much will it cost ???
4g15 doch head ar?? after so many visit to chop chop shop in klang.. still havn't seen1...
coz vr rare ma 4g15 dohc..... not popular as well coz power increase not that much.... it is a normal stock mitsu engine.... if u wanna get 4g15 dohc, better get 4g91 dohc engine... produce more power....
