My 1.3 Ee90 Is Jerking
alantan
3,000 RPM
kl
what is teh posibility of this engine problem
it keep on jerking...andjerking...
not much but very irritating
wah...alan got ur ee90 liao arr?
actually i dun noe abt ee90.
1.3 model is carb or efi?
not sure lah, need FF siffu to help u.
btw, must be a sign....time for transplant :P
since i read earlier u changed our plug cables ... have u tried checking or changing the plugs itself yet ??? or your carbie tuning is very bad ??? cannot think of anything else laaaa ... me newbie maa .. not sifoo acoustic .. heheheheheheeee
Hmmm.... Could be ur carbie dirty or tuning problem? Try to clean ur carbie 1st lor....
carbie cleaned,
sparkie checked-no probs
new cables also
i also dunno what's wrong
carbie cleaned,
new cables also
alantan,
your ee90 comes with 2E 1.312V rite?
your distributor still contact point or electronic?
my 2E last time using contact point...if contact point try
check condensor or contact point condition/gap......
No....... the car telling you that .... want to change engine liao...
hahahahahahaha
cough*cough*cough*
aku dah sakit, kena replacement baru...
hahahahhahaa
anyway, why change to toyota? :)
toyota more comfortable ma....
its still using distributer/contact point...
must checked that wan...
[snapback]880094[/snapback]​
alantan,
can check ur fuel consumption o not?
1.3 12 valve engine is 2E-E
2E is 1.3 8 valve.
jerking when idling?
ur platinum in the distributor lar
change to electronic type....
another thing..My car keep jerking as well....Solve the problem when my compressor bearing almost kong
then no more jerking,.
I just changed that part few days ago. Its a little contact switch that clicks every revolution. BTW i saw the packaging and it is listed as arm. I assume distributor condensor arm. I also have bad jerking problem like yours. But now fixed liao. :) Also remember to blast the air filter clean from inside out. Damn much improvement to engine response.
now let me describe deatail..what is teh problem
mine is 1.3 12valve so i assume is 2e-e
its choking...not jerking...
let say idrive in 2nd gear 4krpm..its choking a lill bit by bits...
when i stop in traffic lights,i engage to 1st gear and when i was about to move..i tekan the pedal the rpm go down and dies off..
here;s the problem..why is it choking so badly..
filter is checked..sprakr plus and cvable check...all no problem also..carb also clean clean already..
[snapback]882033[/snapback]​
hi,
i notice u hv checked the spark plug and the cable, but i still cant think of others thing that gives u this problem...
umm...juz wanna share, i had this problem on my old satria 1.3EFI, one of the spark plug not working good, carbon build up all over the plug.
so, the car choke when accelerate on certain speed, and sometime when press the fuel pedal, the car wont response immediately, its like got delay 2 or 3 sec only it start accelerate...
then, after a new set of spark plug, problem solves....
cheer :)
alantan your car jerking but still can drift not bad what... :lol:
change to electronic distributor from denso coz 100++
using 4 spark plug cable and wont have the middle coil cable....
i think ur platinum very thin liao.
