Multiple Whiteline Chassis products for all cars
Whiteline NISSAN 350Z Z33 Rear Sway bar - link assembly
Are you a street driver or track warrior searching for something to quench your "THIRST FOR SPEED"? Let MEGAMANICS WORKSHOP build your dream and we’ll surpass your expectations.
MEGAMANICS WORKSHOP has just the right upgrades for any “Street Drivers or Track Warriors.” Our workshop offers a range of services from servicing & repairs to complete engine rebuilds, drive-line upgrades, suspension upgrades, performance enhancements, modifications and many more for all Road, Performance Street, Drag & Race car applications.
Description:
Performance sway bar links utilising a heavy duty steel ball joint ends that adjust & rotate to any angular combination. Eliminate sway bar preload via the light weight aluminium bodies provide 25mm centre to centre length adjustment.
Price: RM 650.00
Please contact Megamanics Workshop at 0127857113 / 0176527113.
For More information kindly visit us / find us on our Facebook (megamanicsworkshop). We are looking forward to serve you.
Thank You
Whiteline NISSAN 370Z Z34 Sway bar - 27mm heavy duty blade adjustable
Descriptions:
This Whiteline 27mm 2 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Price: RM 1130.00
Thank You.
Whiteline NISSAN 370Z Z34 Sway bar - Sway bar - 24mm heavy duty blade adjustable
Whiteline NISSAN 370Z Z34 Sway bar - 24mm heavy duty blade adjustable
Description:
This Whiteline 24mm 3 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Price: RM 1050.00
Thank You.
Whiteline HONDA CIVIC FD2 TYPE R Sway bar - 27mm heavy duty blade adjustable
Description:
Price: RM 1070.00
Thank You.
Whiteline HONDA CIVIC FD2 TYPE R Rear Sway bar - 22mm heavy duty blade adjustable
Description:
This Whiteline 22mm 2 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Price: RM 1070.00
Thank You.
Whiteline Subaru V10 Sway bar - 24mm X heavy duty blade adjustable
Description:
This Whiteline 24mm 2 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Price: RM 1050.00
Thank You.
Whiteline Subaru V10 Sway bar - 22mm X heavy duty blade adjustable
Description:
This Whiteline 22mm 3 point adjustable sway bar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Price: RM 1070.00
Thank You.
Whiteline Mazda MPS FRONT SWAY BAR 27MM HEAVY DUTY BLADE ADJUSTABLE
Description:
Price: RM 1070.00
Thank You.
Whiteline Mazda MPS REAR SWAY BAR 27MM HEAVY DUTY BLADE ADJUSTABLE
Description:
Price: RM 1070.00
Thank You.
Whiteline Mazda MPS FRONT SWAY BAR LINK ASSEMBLY
Description:
Price: RM 650.00
Thank You.
