refer to the wiring manuals included bro..
ahhl said:ftzone
look intresting..this shift light, what is it for ah..sori to ask (as dono about car)
if i hook to ecu diesel engine, will it work? and how much for shift light only?
er..one more thing, beside to ecu rpm wire, where else it need to be connected to make the shift light works?
it will read from the diesel engine ecu... btw ahhl, shift light alone will not work without any control module... pivot or tachometer with built in shift light also got their control module you know...ftzone said:no sure about diesel engines. shift light alone with not work with the control unit.
ftzone said:ahhl,
shift light is used as an indicator or warning light that your RPM has reach optimum range (user selectable) for you to upshift. Therefore reducing drivers' stress to look on the RPM dial all the time to make sure he/she doesn't shift too early or too late. Shifting gears too early or too late will reduce the engine capabilities to perform for best results in a drag or in a race.
Pivot is a brand name for performance products from japan.
kruger said:install the rpm shift light today... damn satisfied with it!!! :D quote me as a full belly satisfied customer... :D kekeke... the shift light is blue in colour and blink just like a strobe light! wahlauweh!!! check out my diy thread how to install this rpm shift light product http://www.zerotohundred.com/newforums/showthread.php?t=39708
ftzone said:Good News Guys! In conjuction with celebrating Merdeka, ZTHrians are entitled to buy the G'zox Digital RPM, Shift Light & Volt Meter at a special price of RM125 with any purchase of Sparco 4-Point Harness at RM148 or any other purchase above RM300 in a single order.
eg.
Autogauge Water Temp = RM119
Autogauge Oil Temp = RM119
Autogauge Boost Meter = RM99
Total = RM337
Add = RM125 (G'zox RPM) *regular price RM160.00
Grand Total = RM462.00 (QUOTE]
Wah......good promotion leh........ :flute: I also wan ..... still hav stock ar ...
I still at penang, duno went hav time go back BM leh ?? Reserve the belt & G'zox RPM for me ... Ok?
boys + girls,
