Mitsubishi Storm Midifications
Hi,
may i know what can you do to increase the power of the 2.5 litre turbo intercooler mitsubishi storm. And since its has a turbo, is it possible to install a blow off valve in it??
BOV will increase horsepower meh??..
why not try increasing the boost??.. btw, its a gasoline or diesel engine??... sorry, i noob in cars...
Erm BOV does not give the car more power... but i like the sound of it :P thats why. its a diesel car. i also want to add more power to it, maybe changing the exhaust system and air intake system..
but i wanna find out is it possible to add a BOV into a Mitsubishi Storm
u need to match the BOV for the car,if not it will decrease HP.anyway MIT storm was the worst diesel car,no power,if u boost up the car,the turbine will spoilt.
so there is no way can install a BOV without spoiling the turbo?? another question is what do you think i can do to improve the power of the car??? is it possible to upgrade the mitsubishi storm to a mitsubishi storm evo engine??? since it is the same engine...
Oh ok... then what can i do to improve the power of the Storm?? change the air intake??? exhaust??
first of all, i dunno wat makes ordinary guy so sure that mit storm is the lousiest turbo diesel vehicle, he sounded like he tried all turbo-diesel car like ranger, fighter, rodeo, trooper, sorento, kyron, discovery, freelander, frontier, land cruiser, hilux, prado and so on so forth... every car got their pro & cons, dun just simple gave this kind of comment...
As for performance part, i m using pajero 2.8 diesel turbo, i didnt do much for the performance part... only a volts stabilizer to enhance the electrical part, but my fren invest in air induction, exhaust, and a computer and the performance kinda good... overseas user replace the turbine and make high boost too...
i have fuel consumption problem with my storm (2.5l diesel turbo) . any recommended workshop to fix? RM110 per full tank only can reach 400km/ full tank.
is this correct?
i'm in jalan kuchai lama area - kl
thanks
for more power in a stormer, my mechanic told me to get a proper exhaust system, not a fancy or noisy one, but one with less restriction, and then he mention sum chip tuning, he recommended those steps but i havent tried any, so not sure of it... bt get sum expert advice buddy, n cheers to ur attempt... :)
Check Unichip I saw there was a significant power after install. If you at JB area you can go to Viswork to test drive.
yah...... check unichip.........you will shocked about the result you get....
viswork......they are "pakar" for tone up 4x4 diesel turbo
Mitsubishi storm is mechanical engine so it wont able to install unichip...
if wish increase power on that vehicle,u can try to modify the fuel pump,it will increase quite a lot on the power.
wanna ask ,how about the FC ? btw , how i contact vis work ? plan to get a storm , but wanna check the FC 1st, full tank how much ? can run how many km? now using toyota unser , rm86 for about 380km only , wanna check got different a lot or no ? thanks
monshi, , i bet u didnt read the previous posts.
i did mentioned my storm fc.
rm110 full tank for 400km.
u do ur calculation.
