Mitsubishi Evo 6 VI Lancer (M) Fully Loaded
bretbaby
Malaysia
Fully Converted to Evo6 inside n outside,except d roof.
4wd with ABS n AYC Wheel Control System
Apexi Power FC D-Jetro ECU w/ Commander
Just overhauled d engine change -->
New Set Wiseco Fully Forged Racing Piston
New Set Eagle Racing Conrods
ACL Raring Bearings N ACL Main Bearings
Balance Crank Shaft Done
1.4MM MMC Metal Head Gasket
Ori Sard Fuel Regulator
Walbro Fuel Pump
HKS 280 Degree High Cam n Valve Springs
Turbine Modify Bigger Fin at Speen to Wheel 20G Now
38MM Waste Gate
Timing Belt is new also
Fully Rally Art Aluminium Piping
Split Fire Spark Plugs (Very² Rare)
HKS Air Filter
Ori HKS Blow Off Valve
Excedy Twin Plate Clutch (loceng)
Cusco Oil Catch Tank
Tein High Low Soft Hard Absorbers
P1 Ori 17inch Sport Rim (support up to 255 - 17 tyre)
Crime Fighter Alarm System
Caliber n Philips Double Din DVD Sound System
Sabelt racing Safety Belt
Defi Boost,Ext Temp,Fuel Prees,Oil Temp w/ Defi Warning Light
Apexi AVC-R Boost Controller
View at Jalan Kuching or Ampang Area other upon appoinment - 0162922236
THANK YOU
yup,still avaible till now,,.,bt nt sure after wednesday ....360hp 42 torque,change d turbine n injector ONLY can go 550hp.....thanks for reply ;p
---------- Post added at 02:10 AM ---------- 6 hour anti-bump limit - Previous post was at 01:57 AM ----------
Price down to 53k now due to my loan for new car almost done
bro...
PM me your best price..
JPJ already done ka? when send for inspection, can pass or not?
53K is BEST Price already,.i pay for change name and inspection,jpj n puspakom no problerm,1st come 1 serve since no deposit been received yet ,.,.,
