Mitsubishi Evo 123/VR4 Coil On Plug
cheechain
HI,
THIS IS BRAND NEW COIL ON PLUG (C.O.P) SET UP FOR EVO 1-3 / VR4
KIT COMES WITH 3/16 INCH THICK T6061 ALUMINUM PLATE THAT IS CUT PROFESSIONALLY BY WATER JET ,4 BRAND NEW COILS,CONNECTORS,WIRE SEALS,PLATE GROMMETS ,ALL NEW ALLEN HEAD BOLT HARDWARE ALL PRE WIRED .
PLATE IS HIGHLY TRIPLE SANDED AND POLISHED FOR MIRROR POLISH LOOK!!!
ALUMINUM IS LIGHTER AND BRIGHTER THAN ANY OTHER METAL.THAT IS WHY IT IS USED ON ALL AUTOMOTIVE HIGH PERFORMANCE PARTS LIKE (BOV'S,WASTEGATES,FUEL RAILS,PUMPS,INTERCOOLERS,PIPING,CYLINDER HEADS,VALVE COVERS ETC YOU NAME IT...
1.C.O.P ELIMINATES YOUR OLD WORN COIL PACKS AND SPARK PLUG WIRES.
2.YOU WILL NEVER HAVE TO REPLACE SPARK PLUG CABLES AGAIN
3.YOU WILL FEEL MUCH BETTER THROTTLE RESPONSE
4.GET MORE STRONGER ,LONGER SPARK THROUGH OUT THE WHOLE RPM RANGE.
5.HELPS WITH DETONATION/KNOCK ON HIGH AND LOW BOOST LEVELS.
6.ENGINE BAY WILL LOOK MUCH MORE CLEANER AND IT WILL HAVE A SHOW LOOK.
7.SPARK PLUGS WILL LAST MUCH LONGER.
8.GAIN HORSEPOWER .
9.YOU WILL NOTICE MORE MILES PER GALLON.
10.IDLE WILL BE SMOOTHER.
Chain 0193185319
err price??? i afraid if i buy back here no1 knows how to get it fixed ..
Dont worry bro.. It is very ezy to install by tru professional wireman.. Dont go to those pretend like good one lar. It comes with blueprint on how to install..
bro, can u pm me your wireman contact & loc? i need to rewire my evo wiring..vry messy..thanx
call this number 0162080953 KEN he's only proven wire man in KLANG....
JALAN BATU TIGA LAMA KLANG... BESIDE HOKKIEN ASSOCIATED.
Sign board name KE Tan Electric
check out..
quite number of foreman from sunway, subang, and puchong goes to ken....
price quite reasonable.
yaeh i also heard about him b4 this.. Price also reasonable..
include install togeter ? wat the best price ? for evo3
good stuff......really can feel the difference.....currently using stock evo already..hahaa
