Millers Oils Millermatic DM
Wasmo
MILLERMATIC ATF DM
Gearbox / Transmission Oil (Automatic Transmission Fluid)
Performance Profile
Mercedes-Benz: 236.1, 236.5, 236.6, 236.7, 236.8, 236.9, 236.10
GM: Dexron III H
FORD: Mercon
MAN: M339 Type F, Z1, V1, Z2, V2
CAT: TO-2
ZF: 02F, 04D, 03D, 09, 11A, 11B, 14A,14B,16L, 17C, 4HP 20, 6HP 26 (ATF M1375.4)
VOITH: 55.6335, 55.6336
ALLISON: C4, V730 & TES 389
VOLVO: 97340, 97341
VICKERS: HAGGLUNDS DENISON
RACINE: REXNORD
SUNDSTRAND: CLARK POWERSHIFT
Description
Premium Automatic Transmission Fluid technology blended with selected fully synthetic base fluids.
Application
Use in automatic transmissions and other equipment, which require this type of lubricant, including Vickers, Hagglunds Denison, Racine, Rexnord, Sundstrand and Clark Powershift.
User Benefits
Easier shifting even at low temperatures. Shorter warm up ensures max gearbox efficiency. Stays in grade even under extreme conditions.
Lower maintenance costs. Longer drain periods.
Excellent high temperature oxidation stability up to 100,000 miles under normal conditions Stable friction properties increases durability, to meet longer warranty periods.
Outstanding low temperature fluidity which provides exceptional cold flow properties.
Typical Characteristics
Specific Gravity (at 15°C) 0.862
Kinematic Viscosity (at 100°C, cSt) 7.5
Kinematic Viscosity (at 40°C, cSt) 35.5
Viscosity Index 186
Pour Point (°C) -51
Flash Point (°C) 185
Colour Appearance Odour Red
Brookfield Viscosity at -40 °C, m Pas 19,000
Please contact Charles at 012-358-4378,Please Call and Whatsapp only
