Main Forums
Car Talk
midbox/bullet selection
<blockquote data-quote="Izso" data-source="post: 1064641797" data-attributes="member: 2429"><p>Raspy without drone depends on the material and the design of the muffler. Resonator in general only just reduces the decibels. Don't get gigantic la, just get one that fits the car. Too large might also reduce exhaust speed depending on design. Expensive exhaust bits like Magnaflow will probably not be practical to buy. The Magnaflow highflow catcon last I checked was in the 2k+ range! So I'm sure any of these branded stuff will set you back a lot.</p><p></p><p>If you already have a resonator don't waste money and change it la. Unless the fiber material inside it has worn out? </p><p></p><p>If you want to change a weekend exhaust setup, just make the S-flow muffler interchangeable with a straight flow one. Don't bother touching the resonator. These easy swappable setups is easily DIY if you have a proper flange installed. DIY swapping is easy.</p></blockquote><p></p>
[QUOTE="Izso, post: 1064641797, member: 2429"] Raspy without drone depends on the material and the design of the muffler. Resonator in general only just reduces the decibels. Don't get gigantic la, just get one that fits the car. Too large might also reduce exhaust speed depending on design. Expensive exhaust bits like Magnaflow will probably not be practical to buy. The Magnaflow highflow catcon last I checked was in the 2k+ range! So I'm sure any of these branded stuff will set you back a lot. If you already have a resonator don't waste money and change it la. Unless the fiber material inside it has worn out? If you want to change a weekend exhaust setup, just make the S-flow muffler interchangeable with a straight flow one. Don't bother touching the resonator. These easy swappable setups is easily DIY if you have a proper flange installed. DIY swapping is easy. [/QUOTE]
R35 Used Titanium Exhaust
AMG GTR now in Malaysia - 5 reasons why it's so devilishly fast
Rear wheel steer works by actively altering the car's wheelbase in a virtual sense, discretely steering the rear wheels in either direction thus improving manoeuvrability at any given speed. This feature greatly help...
HPC 22nd April 2007 - Sepang Circuit
Help: Civic 92-95 Power Window Motor replacement
Hi, I'm new to the Zero-2-Hundred community, and I'm driving a 92-95 civic and hails from Kelantan.
I wonder if anyone can help me with the problem I'm having. I've tried the forum search function, and I couldn't...
Main Forums
Car Talk
