- Joined
- Apr 18, 2006
- Messages
- 3,677
- Points
- 1,663
Hi, I'm new to the Zero-2-Hundred community, and I'm driving a 92-95 civic and hails from Kelantan.
I wonder if anyone can help me with the problem I'm having. I've tried the forum search function, and I couldn't find any threads relating to this problem, maybe I'm using the wrong search terms, and for that I apologize if this is a duplicate thread.
The power window mechanism is a scissors type linkage, and the motor died just recently, and I'm planning to replace it. However, the window is stuck fully closed, and I can't access the bolts to remove the windows, so I can't remove the linkage to replace the motor either. I think there's a manual way to lower the windows so that I can access the mounting bolts, but I can't seem to find it, and the workshop manual I have doesn't help either.
I'm 100 percent sure that it's not a problem with the window's track rails, or the linkage seizing up.
I know that workshops can solve this for me.. but as a DIY person.. I wish to accomplish it myself.
Anyone knows how to manually wind down the windows so I can access the mounting bolts?
Even a general idea will help.. if you have another car using similar linkage for power windows.. maybe you can suggest something.
Thanks in advance for any help offered.
