Noted and thanks for the education. V12 Evo tread wear seems worst than PS3. Price difference not that big. I have V12 on another car.
I thought the V12 and PS3 should have bigger difference then F1D5.
How is the V12 in your other car?
I estimate earliest April, most likely June, you can wait that long? Burning in a ball of flames in a Wira is not as entertaining as a Veyron. I'd be pretty bored without you around.
Bugger!
Ok I can't wait that long and I really don't want to be burnt in a ball of flames in a Wira.
Sigh. Ventus Hankook Sunway Tek Ming here I come I guess.
Bugger!
No complaints about V12 performance, sidewalls feel softer than PS3 in cornering though, and it wears down rather fast compared to PS3. Not surprising considering PS3 has higher tread wear.
---------- Post added at 02:31 PM ---------- 6 hour anti-bump limit - Previous post was at 02:30 PM ----------
Why not the GY F1D5?
I'd prefer the F1D5.. but ultimately it all boils down to $. I'm a stingy bugger.
just waiting for the day where u post a thread - "DIY street spec tyres"
That's beyond my DIY skills la. If I had surplus millions, I'd buy my own tyre fitting machine, an alignment machine, balancer, a Dyno-dynamics dynomometer and a hydraulic car lift. After I buy over my neighbors house and convert it into a garage.
Then you'll see a DIY street spec tyre install.
Hehe.
*dream*
By then, you open for business and for ZTH members discount......![]()
I support ixeo's comment regarding the peeling. so far 2 other tyreman have told me this is a common issue when the tyre comes closer to the 20% mark and depends on tyre usage. this makes 4 seperate tyreman who have confirmed this is the norm.
Ixeo...if u can still get the PS3 at rm260...yr damn lucky or you're spitting those stones at his balls. cheapest i could source was at rm280 a month ago. same shop quoted me rm250 for a pc of F1D5
PS3 - 320 TW rating
F1D5 - 300 TW rating
but looks wise...F1D5 looks more garang with it's straight angle walls and V shaped thread...the PS3 sort of looks like old uncle tyres haha
If just peeling from the corner of the block, then is okay, but for some chunks are coming off....
RM260 is for 195/50R15, Yours is 195/55R15, right?
PS3 rating of 320, also many still say wear fast....:hmmmm:
was quoting 195/55r15. sorry for not mentioning.
my previous ps3 was last changed in september 2011...just changed to another set in november 2012. these are for my fronts. now i got my adjustable uca...can finally correct the stupid inherent negative camber so i expect my new set to last longer than a year.
i couldnt rotate as i have negative camber on the fronts so no matter how well i maintain (alignment each month) i still have uneven wear on the inside. this coupled with lousy malaysian made bushes that fail after a year of use...
but my rears were on 2009 primacy lc n they lasted till my last change in november n could still even get rm40 each in trade in value hahaha
Wah! PS3 front, PLC rear, like drift setup......![]()
:vroam:Always drift in his EG mia...to show off to mini skirts colleagues![]()
Powerslide, the ladies thought is drifting.:vroam:
