Mcintosh MCC602TM
ICE -In Car Entertainment
Mcintosh MCC602TM
vickyz
Selling 1 unit of Mcintosh MCC602TM
Price: RM5000
Contact: 0162510646
MCC602TM Power Amplifier Features
# 300 watts x 2 (2, 4, or 8 ohms), 20-20kHz, 0.005%THD
# Mono: 600 Watts (1/2/4 ohms), 20-20kHz, 0.005%THD
# Dual Pulse Width Modulated Power Supplies
# Balanced Push-Pull Design
# High Current Output (1 Ohm Stable)
# Balanced Noise Canceling Inputs
# Glass Top Plate w/Illuminated Wattmeters that measure both the current and voltage, and Visible Autoformers
MCC602TM Power Amplifier Specifications
Power Output Stereo
Minimum sine wave continuous average power output per channel, all channels operating is:
300 watts into 2 ohm load
300 watts into 4 ohm load
300 watts into 8 ohm load
Power Output Mono
600 watts into 1 ohm load
600 watts into 2 ohm load
600 watts into 4 ohm load
Rated Power Band
20Hz to 20,000Hz
Total Harmonic Distortion
Maximum Total Harmonic Distortion at any power level from 250 milliwatts to rated power output is: 0.005% for 2, 4 or 8 ohm loads (Stereo)
0.005% for 1, 2 or 4 ohm loads (Mono)
Dymanic Headroom
1dB
Frequency Response
+0, -0.25dB from 20Hz to 20,000Hz
+0, -3dB from 10Hz to 50,000Hz
Sensitivity
1Volt balanced or unbalanced inputs
A-Weighted Signal To Noise Ratio
114dB (2V)
Intermodulation Distortion
Maximum Intermodulation Distortion if instantaneous peak output per channel does not exceed twice the rated output, for any combination of frequencies from 20Hz to 20,000Hz, with all channels operating is:
Input Impedance
15,000 ohms balanced or unbalanced inputs
Power Requirements
12 Volts DC, 3.5 amps (idle) - 100 amps (600 watts)
Dimensions
26-7/8 inches (68.3cm) wide, 12-1/2 inches (31.75cm) depth, 4-3/16 inches (10.64 cm) high
Weight
50.5 pounds (22.9 Kg)
