Mb quart dsc2150 sq amp
ICE -In Car Entertainment
danielclarke
Penang
Mb quart Hand Made In Germany Amplifier
this amp was use for only 3 months to power my focal component ..
now i'm letting go real cheap .. lelong selling for over 2.3k ...
i'm letting go only for RM900..
great sq amp to run your component set or sub woofer ..
its over 600 watts peak power ..
guaranteed genuine mb quart with box extra fuse n manual ...
specs below ...
the ratings below are true power unlike some crappy amps .. great sounding amplifier ..
true car audio lover will know the quality of this product..
RMS Power Range : 2x150 Watts
Number Of Channels: 2
Low Frequency response: 10 Hz
High Frequency Response: 1200 Hz
Built In Crossovers: Yes
Channel Separation: Yes
RMS power @ 4 Ohms: 150W x 2
RMS power @ 2 Ohms: 300W x 2
RMS power @ 4 Ohms bridged: 600W x 1
Signal to noise ration: >92dB
Pure Class A/B amplifier topology
Protection and power LED indicators
PWM power supply and high speed MOSFET output devices for superior sound performance
Bass EQ: 45HZ bass boost from 0dB to 9dB
Crossover: Low pass 30Hz-150Hz, High pass 10Hz-1.2KHz
Ultra-flexible and variable adjustable active crossover network
Remote jack enable a dash mount control for the BASS EQ in LP mode
Input level: 0.2V-6V
Full range preamp outputs for easy daisy chaining of additional amplifiers
Product Weight: 7Kg
1 Year Warranty By Local Distributor
box , manual and spare fuse will be given ...
COD in penang or ship by poslaju at your expenses .
