Lotus 2Eleven Track Car
davidv00
Selangor
The new Lotus 2-Eleven takes the Chapman philosophy of ‘Performance through Lightweight’ to its most extreme level yet.
Weighing in at just 670 kg (1,477 lbs) - dry weight with base specification - 745 kg (1639 lbs) - kerb weight, fully loaded - and with 255 PS (252 bhp / 188 kw) on tap courtesy of its supercharged and intercooled 1796 cc engine, the 2-Eleven boasts a power to weight ratio similar to that of a 1960s Formula One car. Designed with the most serious of track day enthusiasts in mind, the Lotus 2-Eleven offers race car levels of performance coupled with legendary Lotus Ride and Handing to deliver a truly outstanding track day car.
The Lotus 2-Eleven is initially available in Launch Edition specification only, which boasts a dynamic and unique three-way Lotus Sport colour scheme complete with decal pack. The Launch Edition is available in two versions - Road Going Version (UK Single Vehicle Approval) fitted with lights, exhaust catalyst, single plane rear wing and other equipment to comply with UK road legal requirements and Track Only Version with an enhanced aerodynamics package including high downforce single-plane carbon fibre rear wing, high downforce front splitter, brake lights, rear indicators and FIA approved driver’s race seat.
Engine
2ZZ-GE engine, Metal Matrix Composite (MMC) & aluminium lightweight and compact construction.
Chain driven Double Over-Head Camshafts (DOHC) exploiting a Variable Valve Timing & Lift - intelligent (VVTL-i) system.
Lotus T4e engine management system, multi-point sequential fuel injection, electronic ignition and electronic throttle control.
Lotus Sport developed supercharger installation with unique rear mounted air to air intercooler
Max Power 255 PS (252 bhp/188 kW) @ 8000 rpm
Max Torque 242 Nm (179 lb/ft) @ 7000 rpm
0-100 km/h 3.9 secs est
More information about car specs, click here.
Download PDF Lotus 2Eleven e-brochure here.
Source: Lotus officials site
why never use campro engine....after all the hype proton made about r3 and motorsports.........
