Light Weight Crank Pulley ~ Works Engineering
Timeattacker
Johor Bahru
WORKS Light Weight Crank Pulley;
Description:-
Weight reduction is how we are able to increase horsepower. Each pound of weight removed from the crankshaft is worth approximately 2.7HP, and our stock diameter crank pulleys are at least 60% lighter than the OEM pulleys they replace, our undersize crank pulley could be up to 90% lighter than the OEM pulleys. This weight loss provides even more spectacular gains than force induction, nitrous, VTEC and increased RPM’s..
P/S: There are no adverse effects from using any of our pulley versions. Bolt them on and forget about them, then just follow your vehicles normal maintenance schedule.
Available For:-
* W-CP-350Z = Crank Pulley Nissan Fairlady Z33 350Z (3-pulley set);
* W-CP-S1415 = Crank Pulley Nissan S14/S15 (3-pulley set);
* W-CP-EVO1-3 = Crank Pulley Mitsubishi Evo 1-3 / VR4 / Perdana (Pro Balancing Series);
* W-CP-EVO7-9 = Crank Pulley Mitsubishi Evo 7/8/9;
* W-CP-4G93 = Crank Pulley Mitsubishi Lancer 1.6 /1.8 / 4G93 (Pro Balancing Series);
* W-CP-4G1315 = Mitsubishi 4G13 / 4G15 SOHC {Non-VDO} (Pro Balancing Series);
* W-CP-H22A = Crank Pulley Honda Prelude DOHC ’93- ’03 (Pro Balancing);
* W-CP-HCDOHC = Crank Pulley Honda Civic SR-4 Vtec (Pro Balancing);
W-CP-HCDOHC2 = Crank Pulley Honda B Series -P.Steering / Alternator (2pc)(Pro Balancing);
* W-CP-R18 = Crank Pulley Honda Civic FD 1.8 ’06-ON (Pro Balancing);
* W-CP-CITY = Crank Pulley City ’03-’07 (Pro Balancing);
* W-CP-F20C = Honda S2000 AP1 (3-pulley set)(Pro Balancing);
* W-CP-WRX = Crank Pulley Subaru Impreza WRX ver 7/8/9 (2-pulley set);
* W-CP-R53 = Crank Pulley Mini Cooper R53 Supercharger;
* W-CP-R56 = Crank Pulley Mini Cooper R56 Turbo;
* W-CP-CAMPRO = Crank Pulley Campro – Gen2 / Satria Neo / Saga BLM / Persona;
* W-CP-K3-VE = Crank Pulley Perodua Myvi / Daihatsu K3-VE 1.3 (Pro Balancing Series);
* W-CP-EJ-DE = Crank Pulley Perodua Kenari / Kelisa / Viva, Daihatsu EJ-DE 1.0 (Pro Balancing Series);
* W-CP-SS = Crank Pulley Suzuki Swift 1.5 / 1.6 (Pro Balancing Series);
* W-CP-TV = Crank Pulley Toyota Vios 1.5 ’03-’06 (Pro Balancing Series);
* W-CP-TW = Crank Pulley Toyota Wish 1.8 ’03-’08 (Pro Balancing Series);
* W-CP-FT86 = Crank Pulley Toyota GT86 / Subaru BRZ / Scion FR-S 2.0 (3-pulley set).
Shall there is any inquiry, kindly contact us @:-
016.964.5648
Thanks For Viewing.
