Injectors and Camshaft
simplythebest
1,500 RPM
Selangor
Hi,
I have some questions.
1. Will there be any difference, if I change the injectors? I'm currently running a 4G13P. Is it a necessary for me to get a adjustable fuel regulator afterthat?
2. If I choose to use High cams 272 degree, what kind of settings or precaution should I take note, in order not to let the car stall?
Thanks.
i think in one of the pages in "Carburater Section" got talk alot about cam degrees ... maybe u can search there...
and .... fuel regulators for N/A car got use ar? :hmmmm: if the car quite stock .. juz change extractor n air filter only.. No use right?
1. Your car will be "rich" that is too much fuel for no increase in power. Yes u can reduce fuel using adjustable fuel regulator but without any mod at all, it's a total waste.
2. Set the idle slightly higher.
