pciericagp said:If it can be fitted. Will effect the ECU, tell the ECU doing wrong thing. How really AE101 T/B work and talk communicate with Mitsubishi ECU and TCU. Really doubt about it but worth to try since Toyota Corolla AE101 / AE111 seldom facing problem...
Your guys know where can I do that? I'm looking for a trusted, experience mechanics to mod it to my car. Now my car was using Perdana Throttle Body. Some problem happen and FC high a bit.
Do educate yourself with a knowledge first, pls browse the whole thread from the beginning:regular_smile:. 4 throttle is "the hardware" ECU is still Mitsubishi, the reading is get from Mitsubishi MAF or MAP with the same TPS, so adjusting is made with SAFC or FPR, get it ?
If you are using MAF, it's very easy to tune, if youre using MAP than we have to cheat the vacuum to give a constant "reading", Toyota 4 throttle has been using to Mitsubishi engine, Daihatsu engine and Vtec engine, but must have the knowledgelah bcoz it's very technical. But it's very easy once you knew the secret.
.. tq..
