How To Stop A Car Without Brakes
sakuraguy
5,000 RPM
Sendai, JAPAN.
Imagine this. You’re exiting the freeway off that killer ramp the one with the steep grade and the hairpin turn midway down. You smash on the brakes, and… nothing. You keep careening at 140kmh toward the guardrail, that broken length of floss that is the only thing between you and a 400-foot dive into a shallow lake full of fire-breathing alligators.
Okay, that scenario is a bit unlikely, but the fact is, brake failure can be a terrifying and dangerous experience no matter where it occurs. While automobile brakes rarely fail, every motorist should know what to do if it happens. Here’s how to control your car safely if the brakes come out.
Step One
Remain calm. It’s easier said than done, but a cool head is essential to safely control your vehicle.
Step Two
Keep your eyes on the road and continue to steer. Pay attention to what’s in front of you, and maneuver to avoid heavy traffic, pedestrians, and dangerous obstacles. The one exception is if your brakes don’t work because something is stuck under the pedal. If that's the case, you should try to remove the object with your foot, rather than bending down to get it.
Step Three
Warn other drivers and pedestrians. Turn your hazard lights on, and honk your horn to make others aware that there is a problem. While they may not be able to figure out what the problem it is, a warning should cause most people to proceed with caution and pay attention to what your vehicle is doing.
Step Four
Pump your brakes. Pumping your brakes several times may rebuild enough pressure in the braking system for you to stop. This may take a while, so keep trying. You should do this even if your car is equipped with ABS as the ABS is only activated when your car is braking too hard, which won't be the problem if your brakes have failed.
Step Five
Shift into low gear. If you have a manual transmission, downshift quickly. You may not be able to downshift directly into first or second gear at high speeds, but go into the lowest gear you can, and try to downshift again once the vehicle slows a bit. With a manual transmission you can possibly stop the car very quickly by slamming it into reverse; according to one report, it spins the drive wheels in reverse momentarily, then the entire transmission fell into the street as the car stopped! If you have an automatic transmission, shift into low range (generally labeled as “1” on the shifting mechanism). Again, if you can’t go directly into the lowest range, try gradually shifting down.
Step Six
Use the emergency brake. The emergency brake, or “parking brake” can usually stop a vehicle, although it will take longer than usual to come to a stop. Apply the brake (depending on your vehicle this is done either by pulling up on the handle or pushing down on the pedal) slowly and steadily. If you pull up the brake quickly, your vehicle is liable to spin out of control.
Step Seven
Slow the vehicle however you can. If the above measures fail to stop you, or if you must stop very quickly, do whatever you can. Ideally, you could use a runaway truck ramp, but as these are not particularly common, you’ll probably have to improvise. Keep in mind, however, that these techniques can be very dangerous, especially at high speeds, and should only be used as a last resort.
Use friction to slow your vehicle. Driving through gravel or dirt (such as you might find right off the side of the road) can slow your vehicle considerably.
Use guardrails to slow your vehicle. Cement dividers are built pear-shaped so that contact is made with the wheels, not with the precious metal and paint of your automobile. Applying friction to the rubber on your wheels will slow the car considerably without harming other portions of your vehicle.
Use terrain to your advantage. Try to seek out inclines that you can go up.
Small trees and shrubbery will slow your vehicle when all else fails. Try to put your vehicle through the center of a line of shrubs or saplings, being careful not to pick a tree that is too heavy for your car to go through.
Hit the back of another car. While obviously not a first choice, it can slow your vehicle. If you’re going to do so, try to warn the driver in front of you by honking your horn. Try to strike a vehicle that is traveling at about the same speed as yours (hitting a slow-moving or parked car will stop you, but the deceleration will be quick and extreme) and attempt to make impact squarely on the back of the vehicle. Glancing blows will likely send both vehicles out of control.
Step Eight
Look for a safe spot to pull over (or to crash). Scan the road ahead for a safe area to pull over once you’re able to come to a stop. If you’re not able to bring the vehicle to a complete stop, look for open spaces that you can coast across without hitting anything.
If the safest spot to "crash land" your vehicle requires you to jump a curb, extra caution must be taken. Even with power steering, the cars' initial reaction will be to rip the steering wheel from your hands, bounce from the curb and back into traffic. It is imperative that you grip the steering wheel in a firm manner and angle your car deep enough into the curb so that it will go up and over, yet shallow enough so that you don't turn the car completely and lose control in a spin.
Overall Tips & Warnings
Several "brake failure" cases are brought about by an object getting stuck under the brake pedal, such as a toy or a soda bottle. Avoid this situation by keeping your car clean and free of debris, especially the area around the driver’s seat.
You can avoid most instances of brake failure by regularly checking your brake fluid and changing it according to the manufacturer’s recommendations. You should also have your entire brake system inspected at regular intervals or if you notice any change in the performance of your brakes. Don’t put off making necessary repairs or performing routine maintenance.
Brake failure is dangerous anyway, but it can be even worse if you’re driving aggressively or negligently. Always avoid "tailgating" vehicles in front of you, proceed with caution in bad weather conditions, and mind the speed limit.
Shift down when going downhill. Overuse of your brakes will cause them to overheat and fail. Shift down and use engine braking.
You will generally not be able to shift in reverse while the vehicle is moving, but if everything short of crashing is exhausted try it. Note that computer controlled transmissions will not do a forward-to-reverse gear change when running above 10–15mph, and that there is a large chance of destroying the clutch packs and brakes in an automatic transmission, snapping the teeth off of a reverse gear in a manual transmission, and stalling the engine in both cases.
Do not shift an automatic transmission into park when moving. The parking prawl that binds the transmission will not be able to support a moving car.
Try steering your car so it goes uphill, as gravity will slow your vehicle down. Make sure to find flat ground uphill to avoid causing your car to go backwards due to gravity.
Do not shut the engine off during a brake failure, as the majority of power steering systems are hydraulically driven, and regulated by engine vacuum. If you do panic and shut the engine off, hydraulic systems typically give you three more power assisted pumps. Turn the key to the second position (accessories) so the steering wheel doesn't lock.
Sudden down-shifts may damage your transmission. This is especially true if you manage to shift in reverse. That said, you must do what is necessary to stop the vehicle.
Once you manage to stop the vehicle, do not attempt to drive it again until you are sure the problem is fixed.
Don't try this unless 100% necessary. Don't strike another car or drive off the road unless it is your last resort, as you could end up killing nearby pedestrians or the occupants of your vehicle.
Happy Motoring
SakuraGuy
Zerotohundred.Com
thanx for dat info SG, brake failure was very scare.. always check our braking systems..
if need to pull up ur handbrake, do it by pull n release repeatly..
Alternative Step
Install parachute at the back, or reverse thrusters on car.
hehehe
sakuraguy,
hope you don't mind me making jokes in your hints and tips thread la. hehehe
