is dat ur car engine pic?
if yes, look at the back of the carb. u will see 2 vacuum pipes, "T"/tap 1 of them.
run engine,rev abit. see if ur meter works.
Moderator please help me move this thread to DIY. I dont have such power.
FYI: mine is carb.
By the way. How the two vacuum hose look like?
I saw some one (jaywat) tap from PCV/valve hose.? Kinda blur now.
Which to tap?, i want to proper way.
will my vacuum meter spoil if i fix it permanently, the needle keep moving insanely.
FYI: i connect between PCV valve and carb.(is tht a carb?) blur case.
Power is relative, at least for petrol heads, and warp speed just doesn’t cut it for some. The Canadian owner of this Chevy Camaro probably wouldn’t fall into that...
just recent drop a b6 turbo inside my car...and changed the oil feed line at the same time service the turbo also.....
when the engine starts to get hot..
white smoke appears...from exhaust...darn damm lots of it...
