how to install pivot shift light,pls help
Mon_key888
Selangor
can anyone help me how to install pivot shift light, i bought this unit 2 months ago and still haven't install because i want to DIY this unit, i need to know the wire connection to my lancer dash board, my car already converted to 4g93t, pls provide me the colour code on where to connect the wire, i can see 4 wire from the unit which is 2 wire for l.e.d, 1 wire for acc and 1 wire for grounding, anybody out there pls help me on this.. :smile:
this one u hv to remove the key switch there la.... tested wit ur test-pen to which wire is acc....grounding u can direct ground it to body..
go here n see la....beter..hehe
http://www.racingdimension.com/index.asp?PageAction=Custom&ID=2
send to workshop n ask them instal beter la if u not sure
gsr evo3
thanks bro, that's really helps, but do you know for acc what is the wire colour code?
tis u hv to test it...
remove ur key switch....open ur key to 'ACC'...then test each wire wit test-pen...see which wire got light ....
if got light.....then to make sure it is 'ACC'...u turn off the key.the light wil gone...then when u switch to acc, then light wil ON...
good luck....
