how to differentiate blacktop 5 speed & 6 speed ECU
zerostar78
miri/sarawak
hi guys,
lately i bought a 6 speed M/T BT ECU complete with wiring for my younger brother. As i'm using ST, i cant compare the different of these two ECU. I'm curious to know how to identify and differentiate them.. i only know dat both pin holes for each MT/AT ECU's are the same (correct me if i'm wrong, he3..) btw, if someone has a good picture inside the ECU and can post them here for my reference i should be glad..
thanks all toyotarian...
i did notice the sticker 86 on the casing, apart from that, is there any difference in term of view from inside the ECU itself.
btw, got another question just pop in my mind, he3.. which ECU is the best in term of power & FC? or are both the same?
thanks in advance.
last time, got 1 seg owner.....he is using BT5 speed engine.....he borrow fr his uncle a 6 speed ecu n put in his car......he told me his car even faster caompare to his uncle car wheres is 6 speed engine.......just share
---------- Post added at 02:46 PM ---------- 6 hour anti-bump limit - Previous post was at 02:45 PM ----------
yeah......he said 6 speed ecu is faster compare to 5 speed ecu
rev cut
5sp - 7900 - 8000 rpm
6sp - 8100 - 8200 rpm
5sp bt chipped by blitz - 8500 rpm...he he he
standalone - any rpm u want.. kidding only...he he he
[5sp ECU]
89661-1A470
Grey connector
7800rpm
[6sp ECU]
89661-1A860
White Connector
8200rpm
*At cold weather, the ECU allow 5% up in the rev cut
*6sp ECU has more aggressive fuel mapping compare to 5sp
*Both ECU has exactly similar component count and board lay out pattern
And yes both A/T and M/T ECU share the same connector, pin-out and even the board lay out pattern
Attach pix are 5sp ECU
noted.
thanks all toyota's sifu for your comment especially to bro levin 818 :rock:.
later belanja u all minum coffee: if u guys sudi+free, wait i come to kl dis jun. he2..
hi..
done comparing both ECU last night and found out that both are same. However i'm still not satisfied because there must be slightly different for both ECU or else why toyota produce this kind of ECU for both transmission? hmm, my last thought is perhaps the seller con me? :mad:
Check IC601's software masking code.
5sp - D151804-8080
6sp - D151804-9531
This is the chip that deliver the differences.
---------- Post added at 10:37 PM ---------- 6 hour anti-bump limit - Previous post was at 10:11 PM ----------
It is not all 5sp and 6sp ECU has IC601 with above masking code.
I have seen (only once) 5sp ECU with D151804-5xxx, and also a 6sp ECU with D151804-7xxx.
However, most 5sp and 6sp ECU has 8080 and 9531 masking code.
hi bro levin818,
referring to your pic and i found out dat its indeed a 6 speed wit code D151805-9531
thanks again bro. really2 appreciate your help.
Wow u mean 5 speed gearbox can use 6 speed ECU ??
