Main Forums
Car Talk
Car Modification
Hotbits Exhaust System
<blockquote data-quote="Zeroed" data-source="post: 4349144" data-attributes="member: 98"><p>????</p><p>You should read up more about exhaust systems first... Google is your friend. Exhaust systems do not change "modes"! Only some mufflers do.</p><p></p><p>Hybrid extractors are basically 4-2-1 extractors with longer primary runners.</p><p>This allows it to have a better top end range like the 4-1 extractors, but maintain a good amount of low end power as well. Think of it having a long "4 pipe" portion and a shorter "2 pipe" portion before connecting to "1".</p><p></p><p>There is no such thing as an extractor which is good from low to high rpm, you have to choose your optimum powerband to focus on. Hybrid extractors have a slightly wider powerband range, but are not as good as 4-2-1 for low end and 4-1 for high end.</p><p></p><p>Of course, a well designed extractor will perform better across the entire rev-range than a chaplang extractor, but assuming that it is manufactured to the best standards, you have to choose an optimum range.</p><p></p><p>The mugen twin loop doesnt change modes, its just a straight flow that goes into the muffler body twice. DC5, EP3 and FD2 stock mufflers have the "modes" thing youre saying in the form of a flap in the muffler body, which opens during high pressure and allows gasses to by-pass the usual route and go straight into the outlet. Meaning low pressure its S-flow, high pressure its nearly straight-flow.</p></blockquote><p></p>
[QUOTE="Zeroed, post: 4349144, member: 98"] ???? You should read up more about exhaust systems first... Google is your friend. Exhaust systems do not change "modes"! Only some mufflers do. Hybrid extractors are basically 4-2-1 extractors with longer primary runners. This allows it to have a better top end range like the 4-1 extractors, but maintain a good amount of low end power as well. Think of it having a long "4 pipe" portion and a shorter "2 pipe" portion before connecting to "1". There is no such thing as an extractor which is good from low to high rpm, you have to choose your optimum powerband to focus on. Hybrid extractors have a slightly wider powerband range, but are not as good as 4-2-1 for low end and 4-1 for high end. Of course, a well designed extractor will perform better across the entire rev-range than a chaplang extractor, but assuming that it is manufactured to the best standards, you have to choose an optimum range. The mugen twin loop doesnt change modes, its just a straight flow that goes into the muffler body twice. DC5, EP3 and FD2 stock mufflers have the "modes" thing youre saying in the form of a flap in the muffler body, which opens during high pressure and allows gasses to by-pass the usual route and go straight into the outlet. Meaning low pressure its S-flow, high pressure its nearly straight-flow. [/QUOTE]
(Nearly) New Airtrek Owner
Hi everyone,
Nearly the proud owner of a 2003 Airtrek Turbo R in Black!
Importing from Japan to UK, have to wait until 6th March for arrival, very excited :)
Plans
Evo 8 Wheels
Gaz Coilovers
Evo Recaros
Evo...
jb
lancer jB angkat tangan...nak kira..hehe
AR80 & TD05
hello ppl
just wondering is Garrett AR80 smaller than TD05??
but from what i heard is the Air Ratio for Garrett AR80 is bigger than TD05 is it true??
most ppl tend to look at the size of the fins TD05 is bigger but...
Main Forums
Car Talk
Car Modification
