Hondata K-PRO With ECU For Sale
KOF
Hay i want to sale Hondata K-PRO With ECU, i used only 15days and then i sold my car.
For K-Series Engines K20A, K20
The Hondata K-Series Programmable ECU (K-Pro) consists of a hardware modification to any Honda K-Series ECU, plus Windows software which allows you to re-program the ECU and data-log sensors.
Main features:
  • KPRO components are contained within the ECU
  • USB connection for speed and compatibility
  • KManager Windows based software for parameter & table editing, calibration uploading and datalogging.
  • Many built-in calibrations for common engine combinations
  • Built in datalogging to a laptop
  • On board datalogging memory (2 MB memory, 10-110 minutes datalogging)
  • Adjustment for different sized injectors, with overall fuel trim.
  • Configurable for any MAP sensor (to 5 Bar and above)
  • TPS based table lookup for ITBs
  • Engine protection from over boost and lean protection.
  • Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
  • Launch control with anti-lag
  • Three multi purpose outputs for nitrous control or similar
  • Supports lambda tracing from the stock wideband o2
  • PWM output for boost control
  • Made in the USA
KManager editing software features:
  • High and low speed 16 x 20 ignition and fuel tables for correct VTEC tuning
  • Injector size fuel trim
  • Fuel trim for starting, throttle tip in and individual cylinder trim
  • Rev limiter with fuel cut
  • Adjustable VTEC window with load and throttle control
  • Adjustable idle speed
  • MAP sensor type and calibration
  • Adjustable boost cut with hot and cold settings
  • Closed loop control
  • Air temperature compensation
  • Fuel and ignition correction based on gear
  • Closed loop
  • Three general purpose outputs for nitrous control, quad boost control or similar
  • On board datalogging trigger conditions.
SOLD
