Help me with DIY voltmeter n vakum meter installation..
  • Thread starter chilskater
  • Start date
  • Replies 28
  • Views 8K
C
chilskater
Guest
hi,
I have 2 unit of those meter. i read the instruction and well..understand a bit lar..but i need some pics or foolproof instruction lar.ahha
please help kancil owner
chilskater said:
hi,
for vacuum meter is easy lah... just t joint any vacuum hose in ur engine then connect to the meter inside ur car...
for volt meter much more easier... just tap the +ve to any +ve line exp smoking adapter... then ground to body only....
ya... very easy only
the harder part is.. how to pull the vacuum tube from engine bay into your car
and another harder thing is how to find source for light for your gauge...
other stuff is pretty straightfoward and easy. :D
good luck in DIY
all wiring under ur steering rack.....use test-pen to see which wire is 'light' one la..which is 'power'.....black can conect to body oso...
hi..
i did try last saturday..but i using wiring from clock..the only diagram i understand..it works but leceh coz have to tarik long cable..im thinking of using the ignition wiring or under the steering rack..i dunno the color code..
black=ground
red=power(12v battery or ACC)
oren=light
and for the vacuum meter..i dun even know which is vacum meter..any pics?
i mean the vacuum hose..i dunno which hose to cut and to be put the T connection....vakum meter i know lar bro..
:P
Mana satu vacuum hose?
http://h1.ripway.com/chilskater/Folder%20Name/Folder%20Name/Stuffs/allconection.JPG
http://h1.ripway.com/chilskater/Folder%20Name/Folder%20Name/Stuffs/DPtobody.JPG
Eh tumpang a little....just wanna ask...i got an extra voltmeter(light no more working) that i wan 2 install in my engine bay.Thought of connecting directly 2 the battery....can ah? thanks.....:X-:
your voltmeter has how many wires? if only 2, then u can connect them to Batt.
BTW, I m frm Sban also, but work in Singapore :shades_smile:
Yeah it got 2 wire....:X-:
Oh ur frm sban too...which part....do join us for tt when ur down here or something....there is quite a number of sban members.....:regular_smile:
my parent stay at Tmn Duyung. My bro is a mechanic in Senawang, crazy in car-mod oso. Mayb u or members there may know him.
BTW, BEFORE u connect ur voltmeter to batt, pls get a handheld multimeter to measure the 2 wires n make sure they r not shorted. This is VERY IMPORTANT! If the 2 wires are shorted, pls DON'T use :emoticon_U:
Mechanic in Senawang?Which shop?
U mean check whether the voltmeter is working or not, is it???
come on...juz a few "say hi" mesg wif fellow forumer frm same home town in your thread also cannot.....After all, we are still talking abt Voltmeter connection.
Skyline, I think I will stay away frm "this". You've got mail :)
no hard feeling bro,u still can PM each other..for me sabahan kereta is absolutely creative n kaw kaw best.. :) anyway..i manage to find the vakum hose and will proceed to do the installation during CNY..
Hepi CNY to all..
chilskater,
bro...sorry for hijacking ur thread la bro....:_:
wyx,
yeah i think it's best we "pm"ed each other la...or maybe you can join us in sban thread under "gathering and meet-ups" .........
