guys currently im having prob, when i press the clutch, the wheel area has a cliking sound.. only when when the car is moving and when clutch is in.. anyidea what could be the prob..? pls help...
today i realise the sound is there even when driving but not so noticible unless press clutch pedal.. and the sound is from driver side.. i check under the car i saw my drive shaft cover bocor and the grease is pouring out.. could this be the cause of the sound? how much to change the cover and put the grease..
hey man, today i found out that i need new brake pads... any idea how much ori toyota ones? anything better than ori one..? using ae101 single pot.. thanks dude
I would like to ask something about o2 sensor. Currently my car was doing bolt-on turbo and everything is fine except Engine Check Light on. Once the CE light on, TRC and VSC system disable which I...
